Coloured capacitors - mean?
  • EvilCensor
    • Jan 2011
    • 8
    I've recently bought an old MSI motherboard with 4 x 1500uf 16v capacitors one of which is showing very obvious bulging on top.
    These caps are brown in colour - I'm unclear as to what this means, should I only replace with brown caps (what do the colours mean)?
    Apologies to the informed for what may seem a silly question.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Coloured capacitors - mean?
    Color has no bearing on electrolyic capacitors. In general, I would choose a low ESR capacitor like Rubycon MCZ or Panasonic FM as a replacement.
    --- begin sig file ---
    --- end sig file ---
    • EvilCensor
      • Jan 2011
      • 8
      Thank you for your reply, I appreciate it.
      • EvilCensor
        • Jan 2011
        • 8
        The capacitor in question has KZG on it, if I'm not mistaken that's supposed to be a reliable type?
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          kzg is problimatic.replace with mbz
            master hoarder
            • May 2008
            • 12175
            +1
            The brown caps on your motherboard are likely made by Unitec Chemicon (as indicated by the little logo that looks like a shield and the "Y"-shaped vent on top). KZG indicates the series. While United Chemicon is indeed a reliable Japanese capacitor brand, their KZG and KZJ series do go bad quite often.
            With that said, it is best to replace all United Chemicon KZG and KZJ caps above 470uF on your motherboard. As kc8adu said, Rubycon MBZ should work fine. For other replacement options, see this list:
            https://www.badcaps.net/forum/showthread.php?t=2280
            Basically just open the KZG datasheet, and then compare it with the other datahseets. Choose the replacement capacitors so that they have the same or lower ESR/impedance and the same or higher ripple current.
            • dragon3x
              by dragon3x
              power on.
              Here are some examples :
              switching supply area).
              than 6.3 V.)
              03-21-2025, 02:46 PM
            • slybunda
              AA and AAA battery charger capacitors?
              by slybunda
              hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
              it has inside:
              2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
              2 x 470uf 16v LZ105c branded as G.Luxon
              not heard of these brands are they any good?
              iv attached photos of the charger and the board inside for an idea on the type of...
              12-24-2023, 04:41 AM
              After all of...
              07-13-2024, 08:14 PM
            • Cama
              Solar Inverter - SMH-II - 2 missing capacitors
              by Cama
              I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
              My model is : EASUN SMH-II 7 KW
              Mother Board : P/N 18947-002401250250
              Maybe the EASUN SMH-II 4.2 KW have the same capacitors
              Thank you...
              09-12-2025, 02:50 AM
            • Ady2017
              Are there any datasheets available for Elna RJG capacitors?
              by Ady2017
              I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
              05-25-2025, 02:19 PM
