Capacitors for the SMPS enviornment?
  • alexanna
    • Mar 2010
    • 1346
    Are all the series capacitors listed in the,
    “What capacitors should I use”, thread acceptable for the SMPS, or a switching environment?
    Or are there any you should not use?
    Al.
  • Agent24
    I see dead caps
    • Oct 2007
    • 5027
    • New Zealand
    Re: Capacitors for the SMPS enviornment?
    Depends what part of the SMPS you are referring to.
    -David VanHorn
    • TheLaw
      • Jan 2011
      • 477
      Smoothing part of the SMPS should be low ESR, high capacitance.
      Primary side/PFC circuit's big cap should be high voltage, have the proper ripple current, and have as much capacitance as possible.
      • Agent24
        I see dead caps
        • Oct 2007
        • 5027
        • New Zealand
        I would also add it depends on the original capacitors too.
        If you are replacing capacitors in a PSU then usually it's sensible to get ones which match the originals, but with a better quality brand.
        As a general rule, the replacements should have the same ESR or lower and Same Riple current rating or higher. If you change ESR too much you may cause problems in the circuit.
        For that you need to look at the datasheets of the original capacitors and the new ones.
        -David VanHorn
        • alexanna
          • Mar 2010
          • 1346
          Al.
          I don't think I asked the question correctly .This is the thread I was talking about https://www.badcaps.net/forum/showthread.php?t=2280
          Nichcion PW is of lower quality than HZ. Say for example could the PW series be used for a start up cap without causing problems down the road?
          Or some of the other brands series that are on the left side of the list, Left being poorer quality and the better quality being towards the right?
          Al.
          • dragon3x
            After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
            by dragon3x
            Hi, I have some 32 bits computer motherboards that need repair, as they fail to
            power on.
            Here are some examples :
            (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
            switching supply area).
            (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
            than 6.3 V.)
            1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
            I replaced capacitors with aluminum-polymer.
            3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
            03-21-2025, 02:46 PM
          • slybunda
            AA and AAA battery charger capacitors?
            by slybunda
            hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
            it has inside:
            2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
            2 x 470uf 16v LZ105c branded as G.Luxon
            not heard of these brands are they any good?
            iv attached photos of the charger and the board inside for an idea on the type of...
            12-24-2023, 04:41 AM
            by sam_sam_sam
            After all of...
            07-13-2024, 08:14 PM
          • Cama
            Solar Inverter - SMH-II - 2 missing capacitors
            by Cama
            I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
            My model is : EASUN SMH-II 7 KW
            Mother Board : P/N 18947-002401250250
            Maybe the EASUN SMH-II 4.2 KW have the same capacitors
            Thank you...
            09-12-2025, 02:50 AM
          • dkneyle
            Onkyo DX-V500 Laser Disc Player - weird SMPS fault
            by dkneyle
            This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
            Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
            02-01-2022, 02:08 AM
