How do I know if I killed the board?
  • peakbagger66
    • Aug 2005
    • 7
    OK, the title sounds obvious, but if the board still does not work after recapping, how do I know if I damaged one of the tubes or foils while desoldering as opposed to it being another issue preventing the board from posting? I've just removed the old caps, but I used what may be questionable technique with the solder sucker and a needle. Foolish, I know, I know...
    Thanks!
  • arneson
    • Sep 2005
    • 1267
    Re: How do I know if I killed the board?
    Check your resoldering very carefully on each cap.
    A good light and a jeweler's loop gives a magnefied view of those connections that are closely ringed by ground plane.
    Jim
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      did the board still post just before the recapping?
      • peakbagger66
        • Aug 2005
        • 7
        No - the board didn't post at all. I haven't capped the board yet. I was just checking to see if there was a way to visually inspect the holes to determine if there was any damage. I'll get the caps soldered in today and we'll see...
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          measure vcore. be careful it is not a cpu killer. anyway there is possiblilty of more work than recapping - fet/vrm chip damage. tell us how it goes.
          • peakbagger66
            • Aug 2005
            • 7
            Oh I forgot, I did test against a known good power supply. I am pretty sure it was the caps - when I was desoldering them, one of the big ones started "sizzling" and when I pulled it off there were some liquid droplets...definitely some leakage happening. oy...that would suck if I killed a perfectly good board...
            • willawake
              Super Modulator
              • Nov 2003
              • 8457
              • Greece
              that can happen even with crappy caps that are new. not recommended to re-use caps removed like that. sounds like you had some good heat there anyway.
              you probably didnt damage the board. but what i am saying that it may still not post because of damage when the caps failed. in case it does not post dont start trying to do the recapping again, just post your results and we will assist you with the troubleshooting.
              • peakbagger66
                • Aug 2005
                • 7
                OK, so I've soldered the caps in, the board (a shuttle FV25) still does what it was doing before - not posting.
                When I plug the power connector to the back, there is a green led that lights up on the motherboard, near the memory slots. No clue what it is for. I hit the power button, the cpu fan twitches, and then nothing.
                Any ideas?
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  Any ideas?
                  shorted vrm fet.
                  psu hits oc limit instantly on power up.
                  look for shorted mosfets.
                  • peakbagger66
                    • Aug 2005
                    • 7
                    Originally posted by kc8adu
                    shorted vrm fet.
                    Oh drat. What's a MOSFET?
                    Black rectangle with three prong things sticking out of it? I think I am at my limit here...any pointers as to where I should touch the needle? I can post a pic of the mobo...although I wonder if I should let dead horses stay dead...
                    • Chris1992
                      • Apr 2005
                      • 561
                      yeah, the MOSFET is as you described. Why does willawake's sig say 'Merry Christmas, you wanker'?
                      The great capacitor showdown!
                      • kc8adu
                        • Nov 2003
                        • 8832
                        • U.S.A!
                        if you really need to save the board it may be best to send it in.
                        fet is a black square smt soldered to the board .
                        has two pins at one end.
                        think of them as switches.
                        if they stick on(short) the psu is connected across the inductor permanently.
                        psu shuts down from overload.
                        to further complicate things the pwm chip often gets killed too.
