Introducing The New Generation Of Counterfeit Capacitors
  • mockingbird
    • Dec 2008
    • 5484
    So I was at the electronics shop today, and instinctively I beelined toward the capacitors section. they got quite a lot of new stuff and for some reason got rid of a lot of their old stock GP caps.
    What I discovered was astonishing.
    Notice the Panasonic T vents are being used on these obviously fake green Nichicon HD, HN, and HM. These guys are learning. Gone are the days when all you had to do was look at the bunge. The bunge on the last capacitor on the left, a Panasonic FC 10V 2200uF, looks impeccable but this is NOT a real Panasonic FC, it is also a fake. A very good fake. It is rubber and not synthetic like a real FC. It's also flimsy, if I put a little pressure on it, it recedes into the can. Sorry about the image quality on the bunge shot.
    Sorry, no inline pics, files are too big. Also, for some reason PHPBB is further compressing my JPGs.
  • Pyr0Beast
    • Feb 2009
    • 406
    Re: Introducing The New Generation Of Counterfeit Capacitors
    Oh they are getting really good. On the last photo, the one on the right looks a lot like a real one (no stamping marks and a completely flat top).
    Just waiting when they are going to be the same, even in quality specs
    • c_hegge
      • Sep 2009
      • 5219
      Even the rubber seals look like panny. Maybe they are really made by panny?
      • mockingbird
        • Dec 2008
        • 5484
        I'd be more than willing to send these to someone with an ESR tester. The FC is most definitely a fake, eventhough it looks almost completely real.
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          and since nichicon does not use that shade of green....
          the print looks poor too.
          i have already found some of the green vz in a board sent in to be recapped.blown up.fake.
          • smason
            • 1652
            Originally posted by mockingbird
            So I was at the electronics shop today, and instinctively I beelined toward the capacitors section..
            What shop was this?
            • Rulycat
              • Apr 2010
              • 724
              • United Kingdom
              Why would they spend money on making their caps look like pannys? Why not just spend it making good caps?
              • mockingbird
                • Dec 2008
                • 5484
                Incompetance. The countefeiters are physical labourers at best, not chemists or engineers. It's a cheap source of income, and they could probably manufacture good capacitors if they had a competant staff. They lack good intellectual property, not good materials.
                • Rulycat
                  • Apr 2010
                  • 724
                  • United Kingdom
                  Oh, so they essentially make the counterfeit caps and buy the foil and electrolyte in?
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    or resleeve whatever.
                    • mockingbird
                      • Dec 2008
                      • 5484
                      From what I understand, there's one main producer of off-brand capacitors (Besides the Taiwanese producers - and this excludes Samxon which does produce many good models) in China called GSC. They distribute their garbage to a myriad of fly-by-night manufacturers who resleeve their garbage and produce new datasheets based on their new "series".
                      Two identical capacitors from these different "manufacturers" are almost never given the same series namesake, but are usually always the same capacitor underneath the sleeving. In fact, if you look at spec sheets for some of them, the specifications per given model match exactly.
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 5027
                        • New Zealand
                        GSC = Garbage Shit Corporation
                        -David VanHorn
                        • japlytic
                          • Oct 2005
                          • 2086
                          The Nichicon PL series unit looks like a resleeved Jamicon or Hermei through its hexagonal vent.
                          • bigbeark
                            • Jan 2010
                            • 661
                            A year or so ago, when I knew nothing of fake caps, I ordered a bunch of those fake green Nichicons. I remember I needed some 10v 1500uv 8mm caps, and these were all I could find on the web. I took one look at them and decided they were fake. The ESR was acceptable, but the capacitance was way low - about 1050 vs the 1500 specified. Needless to say, I didn't use them. Later I found FJ/FL OEMs on the web and these turned out to be the real deal.
                            So whenever I see green Nichicons I see fake. The Panny FC would have fooled me. I would not be buying these anyway as FMs are readily available in North America.
                            • paparazzo79
                              Fake magsafe 2 charger
                              by paparazzo79
                              Hi guys.I bought Macbook Pro mid 2014 15 inch model which did not came with charger.
                              I got new charger but judging by the specs seems it is fake one.Sadly I live in Bosnia and genuine charger is rare to find.
                              what to do?Should I use the fake one?
                              Will it damage the macbook?...
                              10-02-2024, 08:18 AM
                            • Galraedia
                              Fake Caps in Xbox 360
                              by Galraedia
                              I decided to take one of the Rubycon capacitors out of a phat Xbox 360 with a Zephyr motherboard and noticed that all the Rubycon capacitors near the CPU were fake. The capacitors in question are Rubycon MFZ 680uf 6.3V and they all have a bullseye bottom, something not found in genuine Rubycon capacitors. None of them were leaking, they all have the K top, and the system has never been opened before. It appears Microsoft was using fake capacitors in the Xbox 360, or the Chinese facility where the console was manufactured in was using them and passing them off a genuine. Just thought I'd share...
                              02-04-2023, 09:55 PM
                            • w1nk0
                              Thinkpad X1 Carbon 5th Generation DX120 NM-B141
                              by w1nk0
                              Hello!
                              I'm looking for help with Thinkpad X1 Carbon 5th Generation DX120 NM-B141:
                              - no image
                              - fans spins for second or two (not sure why once it is second and once its two or smth)
                              - keyboard and power button lights for split second
                              Not sure about SN because sticker got worn after time.
                              Any help would be appreciated!...
                              07-07-2025, 05:27 PM
                            • Matthew Morrone
                              Lenovo Thinkpad Yoga x1 3rd Generation
                              by Matthew Morrone
                              machine type model: 20LD0038AU
                              system unit serial no: R90RKCWP
                              system board serial no: W1KS88K10YS
                              Current Bios Version: N25ET68w (1.54) Date: 22/8/24
                              i currently have access to the os i can log in and everything but cannot change the bios settings due to supervisor bios password lock. any help with this would be amazing as i have run out of things to try and dont have a reader to create the dump file.
                              my apologies if i have missed something... im a new member...
                              01-05-2025, 09:12 AM
                              Apple iPad 4th Generation 820-3249 Boardview and Schematic
                              Apple iPad 4th Generation 820-3249 Boardview and Schematic...
                              11-01-2024, 02:45 PM
