Elite Capacitors? (450v 47uf power board Toshiba Vestel TV)
  • slybunda
    • Feb 2012
    • 131
    anyone heard of these caps before? at first glance i mistook them to be Elna caps but closer look and it was elite. not sure if they are known failure prone brand.
    also they are 47uf and 450v. why are they so large in height? i can get replacement 450v 47uf caps that are a quarter the height. what am i missing here?
    if i were to replace them what should i be looking for?
    they are on the power board of a toshiba (vestel) tv power board.
    pic attached
  • andrewsawesomr
    • Jun 2022
    • 101
    • United States of America
    Re: Elite capacitors?
    Elite capacitors are not good quality IMO. They are made by a company called Chinaan (website is https://www.chinsan.com/welcome/ ).
    Can you flip the capacitors over and look for a series name?
    • slybunda
      • Feb 2012
      • 131
      ahh, the board is back in the tv now so i cant get a look at them. also they were glued down for some reason.
      good to know they cant be trusted. if i ever have the board out again i will look to replace them.
      what would be good alternatives? i see i can get 47uf in 450v at less than half the height of the cap. that seems odd to me.
      • slybunda
        • Feb 2012
        • 131
        also noticed these VZ(M) caps on the board that are 105c rated. what brand would these be?
        pic attached
        • slybunda
          • Feb 2012
          • 131
          ok so who goes around making fake capacitors of crappy brand ones?
          https://www.chinsan.com/precautions-...te-capacitors/
          that makes no sense to me.?? if your gonna make fakes stick to fake rubycons or panasonic etc. what next fake teapo caps?
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            I'd rate Elite so-so.
            Obviously, they are not 1st tier caps like the "big 5" Japanese brands (Rubycon, Panasonic, UCC, Nichicon, and Sanyo). But they usually do OK in OEM power supplies. Of course, like all of the other 2nd tier caps (i.e. Teapo, OST, Ltec, and etc.), they don't seem to do to well in applications where they see more heat (like LCD monitor power supplies and inverters.) But all in all, I don't mind them too much.
            The 450V ones you show a picture of are probably the primary bulk caps. Being rated for 450V suggests there is an APFC circuit... in which case, that might explain their larger size, as they likely will be a higher ripple current rating series. You mention your replacements are much smaller (shorter), but what brand and series are they? If their RC rating is not as high as the Elite ones currently in the PSU, there's a good chance the APFC will destroy them down the road. APFC circuits tend to be rather harsh on input / primary bulk caps.
            As for the "VZ" caps - those are Nichicon VZ series, which is a general purpose 105C series (i.e. not low ESR/impedance.) H1746 is their date code - made in 2017, week 46.
            • slybunda
              • Feb 2012
              • 131
              Ahh thanks for that breakdown.
              I havent bought any replacement caps i just checked online for 47u and 450v and saw that the caps were less than half the height.
              Guess I need to find out the ripple specsnof the elite caps.
              Will they be low esr ones?
              • lti
                • May 2011
                • 2551
                What's the diameter of the shorter caps? I'd expect these to have an unusually small diameter as well as being unusually tall (so the TV can be made thinner for marketing purposes).
                • slybunda
                  • Feb 2012
                  • 131
                  i think the long ones may be 10mm x 50mm
                    • 31067
                    for high voltage caps - look at rubycon.
                    • slybunda
                      • Feb 2012
                      • 131
                      Do they need to be any special type? Low esr etc?
                        • 31067
                        depends on the circuit.
                        i would aim for 105' temp either way, they last longer
                        • slybunda
                          • Feb 2012
                          • 131
                          Good stuff, will look to swap all caps out next time i have the tv off the wall. Got to check my car ecu now for any cap issues too.
                          • spiros.p
                            • Dec 2020
                            • 89
                            • Greece
                            i use the same elite caps to replace chong x on led moving heads on their primary smps before two years .til now is all ok.the board on the picture looks like the the primary side from tv smps.you can unsolder one or two and test on lcr. my lg flat tv use same form caps it is made to be thin there is no place for bigger caps.the vzs is nichicon general purpose audio caps
                            • slybunda
                              • Feb 2012
                              • 131
                              thanks for that, wonder why they used nichicon and didnt use cheaper ones?
                              • spiros.p
                                • Dec 2020
                                • 89
                                • Greece
                                nichicon it is 2000 hours rated and is cheap series (now is very expensive from ukraine war������)before war was 3 times cheaper here.
                                • slybunda
                                  • Feb 2012
                                  • 131
                                  Nichicon is make in Ukraine?
                                  • spiros.p
                                    • Dec 2020
                                    • 89
                                    • Greece
                                    of course not but the story is all is expensive and the reason is the ukraine war. ridiculous.
                                      HP Elite Elite Slice (ENERGY STAR) Elite i5-6500T Specification for Upgrade or Repair
                                      This specification for the HP Elite Elite Slice (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Elite Slice (ENERGY STAR) boardview and Elite Elite Slice (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                      09-12-2024, 03:44 PM
                                      HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) Compaq Elite 8000 E5500 Specification for Upgrade or Repair
                                      This specification for the HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) boardview and Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request...
                                      HP Elite Elite 7200 MT Elite 7200 i5-2400 Specification for Upgrade or Repair
                                      This specification for the HP Elite Elite 7200 MT can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Elite 7200 MT boardview and Elite Elite 7200 MT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                      HP Elite Elite 7100 Microtower PC Elite 7100 i3-530 Specification for Upgrade or Repair
                                      This specification for the HP Elite Elite 7100 Microtower PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Elite 7100 Microtower PC boardview and Elite Elite 7100 Microtower PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                      HP Elite Elite Slice Elite i5-6500T Specification for Upgrade or Repair
                                      This specification for the HP Elite Elite Slice can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Elite Slice boardview and Elite Elite Slice schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
