Only old boards have badcaps....Right? (Discussion)
  • Chris1992
    • Apr 2005
    • 561
    mod note : this thread split of from the FAQ thread of the same name, in order to discuss the issue of recent boards with badcaps.
    all well and good to see recent intel p4 boards w/ badcaps. would like to see
    amd64 boards with them.
    The great capacitor showdown!
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Only old boards have badcaps....Right?
    chris can you pick out some more threads for recent photos. esp amd cos i am not familiar with the board model names. just post here
    • Chris1992
      • Apr 2005
      • 561
      Actually I haven't seen any AMD64 mainboards with badcaps on this forum.
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        we have no recent (in range of p4 socket 478 or later) amd boards with badcaps on the forum?
        • Chris1992
          • Apr 2005
          • 561
          I was just about to post that. You beat me by a few seconds. Stupid dialup... anyway that Medion board is made by MSI.
          EDIT: No, AFAIK we do not have recent AMD boards with badcaps.
          • Fatal0E
            • Jan 2004
            • 252
            See p4 boards all the time with badcaps, have not yet seen a64 boards with blown caps, but its just a matter of time. My theory is the p4 which uses so much power puts more load on the caps? Not an engineering person so I don't know this for fact.
            • Chris1992
              • Apr 2005
              • 561
              Interesting theory Fatal0E.
              • Rainbow
                • Aug 2005
                • 1371
                P4 also produces much heat. And many new boards use very cheap components.
                • Newbie2
                  • Sep 2005
                  • 885
                  I'm guessing the cheap components are there because the manufacturer wants to save some cash and make the overall product cheaper and plus have lower quality.
                  My gaming PC:
                  AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
                  ASUS M4A77TD AMD 770 AM3 Motherboard
                  PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
                  G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
                  TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
                  WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
                  ASUS Xonar DG 5.1 Channel PCI sound card
                  Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
                  Antec Three Hundred Mid-Tower Case
                  Microsoft Windows 10 Pro 64-bit
                  Microsoft Windows 7 Ultimate SP1 64-bit
                  • arneson
                    • Sep 2005
                    • 1267
                    Re: Only old boards have badcaps....Right? (Discussion)
                    The trend for many companies is cheap cheaper cheapest.
                    Consider the user, theres grandma who turns on her computer for twenty minutes everyday to read some mail and get a recipy, and theres that mail server pounding away 24/7, who's going to have bad caps?
                    Jim
                    • willawake
                      Super Modulator
                      • Nov 2003
                      • 8457
                      • Greece
                      this is correct. i wanna see how these LGA775 and A64 boards are doing in a few years. we are only seeing the real trash like those ost on the ASUS P5GDC-V at present.
                      one of the other probs is that we only see a fraction of what is actually out there, from the people who actually seek assistance to recap. i see a lot of posts on forums where they are just pitching it into the trash and buying a whole new platform.
                      • willawake
                        Super Modulator
                        • Nov 2003
                        • 8457
                        • Greece
                        posted by newbie2 on the other thread
                        You got a lot of good pics willawake. Hope they keep on coming. Mainly these are Socket 478 boards we're seeing have bad caps.
                        __________________
                        A member of the Badcaps.net forums, 3GM forums, and the SysOpt forums!
                        My motherboard (PCCHIPS M955G) is loaded with OST caps and my PSU (Antec SmartPower SL450) is loaded with Fuhjyyu caps which are on the bad caps list. The OST and Fuhjyyu caps still aren't failing!
                        • Rainbow
                          • Aug 2005
                          • 1371
                          At (previous) work, we had 2 machines with Abit SA6R boards - a server and a workstation. The workstation was almost never used (a couple of hours per week), the server was running 24/7. Caps failed in both, first in the workstation, then in the server.
                          • willawake
                            Super Modulator
                            • Nov 2003
                            • 8457
                            • Greece
                            thats really interesting.
                            possible chemical reaction occuring over time not so dependent on use?
                            • ugamazing
                              Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                              by ugamazing
                              I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                              We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                              12-17-2024, 07:05 PM
                            • ugamazing
                              Apple M1 Boards & Exclamatory Error?
                              by ugamazing
                              We've now created a stack of 10 boards that have the same issue, which we suspect to be CPU-related. The issue is very simple--the board will not boot to anything, only showing the exclamatory sign inside a circle. No amount of DFU/restore, wipe/erase, etc, will resolve the issue. No boards have physical damage. We went ahead and replaced the SSD nands on two boards (one 02020, one 02016) and the issue remained exactly the same. We are considering replacing the CPU on one of the boards using a locked CPU, just so we can see if it resolves the issue.
                              Has anyone else run into this...
                              02-20-2025, 09:24 AM
                            • ugamazing
                              Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
                              by ugamazing
                              I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
                              08-31-2022, 07:34 AM
                            • hopkok
                              Legion 5 PRO, 3 boards, same problem, NM-D562 Rev. 3.0 motherboard
                              by hopkok
                              Hi friends, last week I got 3 same boards for repair (NM-D562 Rev. 3.0), same problem, power button light up, but motherboard wont start.
                              3,3V_alw and 5V_alw, 1,8V_alw and 0,75V_alw presented on all 3 boards, no other voltages. 1,2V missing and if I checked schematic right, I need 1,2V and than can be +3VS and +5VS generated after getting SUSP_N signal from KBC? or vise versa?
                              I checked for low resistance on coils, no low resistance.
                              Anyone with same issue like me?
                              Thanks for any help.
                              05-24-2025, 04:21 AM
                            • midnightg35x
                              Panasonic TC-P65S2 SU or SD Boards Bad?
                              by midnightg35x
                              I have a TC-P65S2 that blew an SC board (I had a previous post about some cross references). When I put the repaired SC board in, it worked with the SD and SU boards isolated and SC50 jumped. I reinstalled the SD and SU boards. I did forget to remove the SC50 jumper, but from what I understand about how that jumper works, that should not cause SC board destruction with properly working SC/SD/SU boards. When I turned the TV back on, the SC board blew again. Based on the fact the SC board was working without the SU and SD boards, it at least makes sense that one or both of them is bad.
                              04-22-2019, 05:29 PM
