What Happened Here?
  • bigbeark
    • Jan 2010
    • 661
    What Happened Here?
    I recapped an ASUS CUR-DLS board earlier this year. This is a dual CPU P3 board, with onboard LSI SCSI running 2 866 CU-mine CPUs, running Mandriva Linux.After the recap, everything worked great, but two faults that were there before the recap, were not corrected by the recap.
    The Onboard USB ports were still not working and only one of the onboard SCSI channels was detected and worked. I had put a D-Link USB 2-port card in, but it didn't work either. (Problem is NOT the settings in the BIOS). Still the board worked well. I put it away for a few months.
    Got it out this week, pressed the start button, immediate shutdown. I'm thinking short so I removed the USB card. Now it starts up, but no video.
    Take the board out of the case, test it on the table with PSU and monitor only. Finally pull out one CPU, replace it with a terminator. Now it boots and video works. Replace the bad CPU with a good one of same model#.
    Put it back in the case, boots but gets kernel panic trying to load the operating system. Assume problem with onboard LSI SCSI. Put known
    working Adaptec 29160 in, computer is working again, but Firefox is complaining of obsolete video player.
    Decide to reload operating system. Won't load. Hangs forever. Some kind of
    hard disk error. Swap the CD Drive for a known good one. Load into "Live"
    (Linux) mode. Able to look at the contents of the hard drive, looks fine to me. Shut down, retry, still won't load OS.
    PSU is the same Huntkey that worked before - 350W.
    Going to try to load an operating system onto the offending drive using another machine.
    Any debugging suggestions?
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    Re: What Happened Here?
    You experienced SCSI termination problems in a previous thread
    Are you sure your SCSI cables and termination are OK this time ?
    I've had problems with SCSI devices being detected erratically - turned out to be the cable itself
    Could not believe it - after all, a cable is as passive a component as you can get - just 68 lengths of wire with a plastic coating, and this one had no obvious physical damage
    None the less, the problems just vanished when I used a different cable
    And if you're using 80 pin SCA to 68 pin UW adapters, all bets are off
    I'd suggest trying a cable with an Active terminator on the end of it, and setting all devices, except the motherboard connectors, to non-terminated
    Some SCSI forums I've trawled in the past, suggest Granite Digital as the ultimate solution for connections
    Problem with them is you're paying professional level money for professional level solutions
    Maybe better for your sanity to stop focusing on SCSI, as I've done, and use consumer level components, performance of which is getting better every day
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
      • 31002
      i'v seen lots of ribbon-cables fail, it's in the sockets, the piercing contacts get unreliable because of being pulled by the cable when people unplug the lead.
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        lvd scsi cables are even more fragile than ide since they are not a solid ribbon.the wires are woven and in some cases not even overwrapped.tiny wires are delicate.scrapped a few of these cables back in the day when they were very expensive.
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          all the ones i have seen are woven and then coated in clear plastic. i think i have one with a built in terminator.
          sigpic
          (Insert witty quote here)
          • AJ847.63e
            Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
            by AJ847.63e
            Hi Folks,
            Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
            I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
            The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
            05-06-2025, 10:37 PM
            HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
            This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
            09-12-2024, 02:20 PM
            HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
            This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
            09-06-2024, 10:56 AM
            HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
            This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
            HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook 1000 Specification for Upgrade or Repair
            This specification for the HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load & Asset Tag boardview and 1050 G1 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
