I recapped an ASUS CUR-DLS board earlier this year. This is a dual CPU P3 board, with onboard LSI SCSI running 2 866 CU-mine CPUs, running Mandriva Linux.After the recap, everything worked great, but two faults that were there before the recap, were not corrected by the recap.
The Onboard USB ports were still not working and only one of the onboard SCSI channels was detected and worked. I had put a D-Link USB 2-port card in, but it didn't work either. (Problem is NOT the settings in the BIOS). Still the board worked well. I put it away for a few months.
Got it out this week, pressed the start button, immediate shutdown. I'm thinking short so I removed the USB card. Now it starts up, but no video.
Take the board out of the case, test it on the table with PSU and monitor only. Finally pull out one CPU, replace it with a terminator. Now it boots and video works. Replace the bad CPU with a good one of same model#.
Put it back in the case, boots but gets kernel panic trying to load the operating system. Assume problem with onboard LSI SCSI. Put known
working Adaptec 29160 in, computer is working again, but Firefox is complaining of obsolete video player.
Decide to reload operating system. Won't load. Hangs forever. Some kind of
hard disk error. Swap the CD Drive for a known good one. Load into "Live"
(Linux) mode. Able to look at the contents of the hard drive, looks fine to me. Shut down, retry, still won't load OS.
PSU is the same Huntkey that worked before - 350W.
Going to try to load an operating system onto the offending drive using another machine.
Any debugging suggestions?
