Korea Chemi-con
  • jhjove
    • Nov 2019
    • 8
    Korea Chemi-con
    I recently got a hold of a H/K AVR 7000, currently doing a close inspection of components. It uses an array of cap brands: Yec, ELNA and Korea Chemi-Con. There's evident heat effects; metal discoloration, cold/broken solder joints....and some swollen caps:
    For certain I'm replacing these units, but interesting the ESR readings are excellent and the capacitance is at spec value.
    Never seen such stressed caps that still measure as OK.
    • 31281
    Re: Korea Chemi-con
    are they really bulged though or is it just the plastic cap?
    • jhjove
      • Nov 2019
      • 8
      Re: Korea Chemi-con
      To me the top plastic cap is bulged because of what has occurred within the capacitor.
      I've never seen a "normal" cap with this domed lid, but then I never heard of "Korea Chemi-con".
      Odd thing too is when I lay these on their sides they do not roll....but find their center on the heavier side. So something is not good internally.
      These were on a PCB that was at the bottom of a 3 stack of boards and for certain exposed to high heat. Needless they are being replaced.
      • Pentium4
        CapXon Be Gone
        • Sep 2011
        • 3741
        Re: Korea Chemi-con
        Looks like they got pretty hot, wow. Never seen these before.
        When you press down on the top plastic domes, do they give way easily or does it not want to move? Better yet: pictures without the plastic
        • jhjove
          • Nov 2019
          • 8
          Re: Korea Chemi-con
          The plastic domes do not move. These are firm.
          I guess I will do an autopsy and provide pics.
          • andrewsawesomr
            • Jun 2022
            • 101
            • United States of America
            Re: Korea Chemi-con
            For anyone wondering, Korea Chemi-Con is a subsidiary of Nippon Cheni-Con that makes/made capacitors in Korea. Some of these capacitors were manufactured by Samyoung.
            • jhjove
              • Nov 2019
              • 8
              Re: Korea Chemi-con
              So after autopsy; the verdict: this is (was) a good cap as far as I can tell.
              Removal of the plastic sleeve and top:
              Internal views of cap:
              ESR is still reading "Good cap with LO ESR" and capacitance value looks OK for 4700uF:
              Thanks for watching.
              • jhjove
                • Nov 2019
                • 8
                Re: Korea Chemi-con
                The reply to your question: not bulged. Just the way the plastic cap was constructed.
                A learned lesson for me.
                • Uranium-235
                  Comrade Glimmer
                  • Aug 2007
                  • 5045
                  • US
                  Re: Korea Chemi-con
                  Yeah for large caps, it's common to see plastic covers and sometimes look bloated. Most PSU primaries will have these
                  • japlytic
                    • Oct 2005
                    • 2086
                    Re: Korea Chemi-con
                    I've seen older Samyoung capacitors having the same shield of Chemi-Con.
                    • Ady2017
                      Are there any datasheets available for Elna RJG capacitors?
                      by Ady2017
                      I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
                      05-25-2025, 02:19 PM
                    • Olkus
                      Elna capacitors - fake?
                      by Olkus
                      I have capacitors like this one in the photo. There are differences between other Elna series, I attach foto of Elna RE3. On this green capacitors series is not specified! Fake?...
                      09-01-2023, 02:45 AM
                    • Mark R
                      Does Elna Make any Cap Kits??
                      by Mark R
                      Been searching the universe internet. Can't seem to find a Cap kit with a Nice assortment of Elna caps. Low values and High Values. Anyone have knowledge in regards to this?
                      01-27-2025, 04:07 PM
                    • RUllER
                      chemicon produced by fuhjyyu
                      by RUllER
                      This is not a fake Chemicon, it is genuine
                      Many companies are outsourcing to Chinese factories....
                      01-29-2024, 12:22 AM
                    • chth96
                      Can I replace KME cap with Samxon GF cap?
                      by chth96
                      Hello.
                      I have 29inch LG CRT TV,And Yesterday,Whenever I connect AC power cord to power outlet without switch on, I heard a sound like white noise, And When I switched on this CRT TV, It sometime displayed correctly But usually It won't last more than 20 minute and The screen begin to dark and It finally did not display at all for hours..
                      Today,I dismantled its plastic case and discharged the biggest capacitor(400wv 470uf) which still holds 250 voltage,and I finally detached PCB from cathode-ray tube.
                      I measured ESR value of most of caps in PCB with MESR-100 and I found that KME(25v...
                      04-17-2024, 07:11 AM
