Badly faked pannies
  • c_hegge
    • Sep 2009
    • 5219
    Badly faked pannies
    I pulled these caps of an MX400 video card and replaced them with sanyo WG. They are clearly fakes. Note the K-vents. Also, NHG series are not suited to this application. At least the rubber seal is correct. The worrying thing is, though, the soldering looked professional, suggesting that the manufacturer of the card used them.
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: Badly faked pannies
    Is this an old card? Whats the maunfacturer?
    • c_hegge
      • Sep 2009
      • 5219
      The MX400 is a fairly old card. The brand of the card is GTF, if the heatsink is anything to go by.
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        Gtf: good to fucking... throw away?
        • c_hegge
          • Sep 2009
          • 5219
          I'll hang on to the card, but the old caps can get exploded.
          • moola
            Banned
            • May 2011
            • 20
            Aren't they already exploded?
            • TheLaw
              • Jan 2011
              • 477
              Wow that's bad. Usually semi-big manufacturers won't do that crap.
              • lti
                • May 2011
                • 2557
                That might be a resleeved Rubycon. I have a Rubycon cap that has the same bung design.
                • Curious808
                  Microwave reacts badly to fat
                  by Curious808
                  Microwave seems to react badly to anything fatty. At the mildest, the time display starts flickering. Sometimes, it resets, the display goes black and the remaining time is gone. Sometimes it zaps and crackles. Symptoms seem to be worse depending on how fatty the food is. Goes wild, dimming from about the first second of trying to reheat a strip of precooked bacon. A precooked meatball causes occasional dimming. It works just fine with no-fat foods.
                  Started a couple of weeks ago when I put in a small raw porkchop. After a few seconds, the unit started spitting and zapping, and I...
                  11-15-2023, 10:09 AM
                • verniumEN
                  Acer Extensa 15 EX215-23-R7NG - BIOS, badly need help :(
                  by verniumEN
                  My laptop model is EX215-23-R7NG
                  BIOS chip XM25QU128C
                  Here is my original bin file, as well as how the BIOS chip looks like
                  My situation is if I press my laptop power on, fan turns on for the first five seconds and turns off, no display (not even acer), but power indicator is on, and the CPU gets warm, even caught one time if powered on for long (before an hour) the fan turns on again, is it only right that I'm approaching via BIOS?
                  Before I got into this situation, I was just watching movies, and while turned on, pressed the battery reset button and cleaned...
                  04-21-2025, 02:31 AM
                • ktmmotocross
                  Acer 515-54G badly burned Main power -After repair ACDET is pulled to GND when apply
                  by ktmmotocross
                  Acer 515-54G
                  DA0ZAWMB8G0
                  Board have badly burned Main power and second mosfet After repair ACDET is pulled to GND when apply power
                  i dont uderstand this. Charger ic BQ24780S
                  ACDET 6pin have voltage devider set to R1 110Kohm and R2 20Kohm. pin ACDET have 20K to GND. But when apply power R1 have 19V on one side and 2.3ohm on other side.
                  What is pulling my ACDET down when i apply power even without BQ ic...
                  12-02-2022, 12:03 PM
                • jabam
                  Badly need working Bios for Galaxy GTX560se
                  by jabam
                  Good day, anyone here have galaxy gtx560se vcard? i need working bios for it..
                  i've search online in techpowerup but the bios there has red garbaged color..
                  my card issue is error code43 and it has red garbaged color..
                  anyone can help me?if you have back-up bios for it..thank you
                  10-30-2022, 03:37 AM
                • JOHNARD
                  badly needed HP PAVILION DV6-6159US bios
                  by JOHNARD
                  94v-0 hannstar j mv-6
                  03-22-2021, 01:45 AM
