Talk to me about tantalums
  • jayjr1105
    • 281
    Lately I've been refurbing and modding a lot of gameboy consoles and usually their main filter cap is 100uf 6v. I've been pulling 100 and 150uf 6v tantalum caps from dead macbook logic boards and using them in place of the original electrolytic. They are small and solder in quite nicely. It's my understanding these are solid state with really low ESR and should outlast the console. Is there a difference between the yellow and black ones? Should I avoid tantalums in certain circumstances like audio circuits?
    Ryzen 3600x
    16GB Patriot 3600MHz
    MSI B450 Gaming Plus
    MSI Air Boost Vega 56
    Acer 32" 1440P Freesync
    Rosewill Capstone 750W
    Hakko FX-888D Station
    FX-8802 Iron
    MG Chem .8mm 63/37 RA 2.2%
    • 31277
    Re: Talk to me about tantalums
    i think the yellow and the black/white ones are the same.
    be a bit carefull about black ones that are laser-etched - some are polymer and have a higher capacitance than you would expect.
    btw, i do exactly the same when i fix gamegear's - tantalums from old motherboards
    • uvoll
      • Jul 2023
      • 4
      Tantalum capacitors in audio circuits is a very controverse discussed theme. Some audio gurus are strictly against their use.
      On the other side you can find tantalum capacitors in high end products, even in the signal path.
      If a ciruit is your own design and you find good reason to use a tantalum capacitor, use it.
      If you want to replace a e.g. electrolytic type in an existing audio ciruit, for what reason ever, better don't do that.
      • ChaosLegionnaire
        cracked tantalum cap on a video card. safe to apply power without fireworks?
        by ChaosLegionnaire
        please refer to the attached pics. is it safe to apply power with that tantalum cap like that without causing fireworks? i dont wanna burn a hole through the pcb as the gpu chip is on the other side.
        happened to me once before with a shorted mlcc. shorted mlcc on a vrm power phase burned a hole through the pcb power section but thankfully that was nowhere near the gpu chip. but the video card still ended up in the landfill anyway tho as the burn-through was not fixable.
        so do let me know what u think of the chipped tantalum there. thanks....
        09-08-2024, 07:05 PM
      • jrutla2
        Help Identifying a Tantalum Capactior!!!!! 68 C79 Please help!!
        by jrutla2
        Hello BadCaps Forum! I'm new to the group and hope you guys can help me with something. I have a 2017 Apple imac A1419 board # 820-00609-A that i'm trying to identify a capacitor failure on. The capacitor is a tantalum 68 C79. See pic attached. I've tried to figure this out using the web and unfortunately can't find the information. Can someone tell me what the Capacitance value, voltage, etc is for these 68 C79 caps are? Where could i pick up a replacement? Thanks in advance!!...
        05-03-2024, 04:00 PM
      • Antonynl
        Capacitance and voltage of tantalum?
        by Antonynl
        I have a tantalum capacitors with indicators EB 21 that measures only 22pF. See attached picture.
        Since this is a windmeter that is normally in a very high mast I would like to get the correct replacement capacitor.
        Is there somebody that can tell me what the capacitance and voltage of this capacitor are?
        I don't feel confident that I can figure this out myself after searching around
        Cheers!!
        04-14-2024, 03:19 PM
      • Perry Babin
        Tantalum Capacitors and Heat Sensitivity
        by Perry Babin
        I remember reading somewhere, years back, that tantalum capacitors are sensitive to heating on their negative terminals and using more than a minimal amount of heat could result in damage. Is this/was this ever true?
        04-03-2024, 05:28 PM
      • mo000
        470uf tantalum caps replacement
        by mo000
        hi
        motherboard toshiba C50 PT10F
        i found 2 bad 470uf tantalum in cpu sircuit making short .
        but i only have 380uf tantalum can i replace them with electrolytic caps .
        05-11-2021, 10:44 AM
