NetVista Capacitors - replacements???
  • Captain_Jon
    • Nov 2005
    • 5
    I have a 2 IBM NetVista computers and one has leaking capacitors which are causing constant rebooting issues.
    The one with the problem is a NetVista model 23U. I looked at the motherboard and found several to be leaking. The ones leaking are identified as follows, both types are YEC:
    - 6.3V ; 1000uf ; LZ 105°C
    - 6.3V ; 1500uf ; LZ 105°C
    Where do I get capacitors to switch these with?? Does a Radio Shack (now The Source in Canada!) carry these? Can someone point me in the right direction as to where I should look (in the Toronto region) and which capacitors are recommended as replacements...
  • AK0R
    • Mar 2005
    • 204
    Re: NetVista Capacitors - replacements???
    No, Radio Shack does not supply capacitors that are appropriate for use in a power supply or motherboard.
    Here is a link for good manufacturers and types:
    https://www.badcaps.net/forum/showthread.php?t=588
    (Panasonic FM are even lower ESR than FC, and often cheaper.)
    Here is a link for suppliers:
    https://www.badcaps.net/forum/showthread.php?t=613
    • linuxguru
      • Apr 2005
      • 1564
      YEC are known crap - they have the distinction of bulging and leaking electrolyte even when new in their original packing. I just saw a full pack of YEC yesterday which was reeking of the characteristic ammonia odour of failed caps, and sure enough, there were many bulging caps inside. How this stuff got past IBM's qualification process is a huge mystery.
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        a pic would be nice.
        btw when satillite tv was c band and dishes were 12' uniden recievers that were made with yec caps had to be totally recapped after 1 year.
        had a bunch of cobra 2000 cb's that other techs gave up on.all these tough dogs were open yec caps.
        • Captain_Jon
          • Nov 2005
          • 5
          Thanks for the replies... In hindsight I should have read some of the stickies before posting!!
          Now that I read the 2 suggested threads, I am still looking for some help...
          It appears that the recommended replacement capacitors are:
          - Panasonic FC or FM; and
          - Rubycon ZL
          So I checked on the two Canadian suppliers from the other thread and found that Newark in One carries none of them whereas Digikey carries only the Panasonic products (that I could find!).
          I found the following on Digikey:
          Panasonic # EEU-FC0J102 (CAP 1000UF 6.3V ELECT FC RADIAL)
          Panasonic # EEU-FC0J152S (CAP 1500UF 6.3V ELECT FC RADIAL)
          Panasonic # EEU-FC0J152 (CAP 1500UF 6.3V ELECT FC RADIAL)
          Panasonic # EEU-FM0J102 (CAP 1000UF 6.3V ELECT FM RADIAL)
          Would these be good replacements for the bad YEC capacitors that I currently have?
          Thanks...
          • Captain_Jon
            • Nov 2005
            • 5
            Anyone??
            I am "definitely" not an electronics wizard and as such I really need some advice to make sure I don't install the wrongs ones...
            An additional point... I read on another website that the Panasonic caps with the "S" at the end of the product number should definitely be avoided... is this right??
            Thanks...
            • willawake
              Super Modulator
              • Nov 2003
              • 8457
              • Greece
              the S are the short and fat. you want the tall and thin
              you might as well buy FM series, they are sometimes cheaper and superior to FC, although FC is perfectly fine and what i use
              FM 1000 6.3 = P12340-ND 10mm width
              FM 1500 6.3 = P12343-ND 10mm width
              looking through the catalogue page 966 for FM it is quite interesting
              you can have
              FM 1200 6.3 = P12342-ND 8mm width
              FM 1000 10 = P12354-ND 8mm width
              either of those would be better for replacing 8mm 1000s on the board if they are in rows or close together
              basically the series FC, FM are ok to replace any cap on motherboards, keep to the same or higher voltage and uf. no prob to replace a 1000 6.3 with a 1000 10v or a 1000 6.3 with a 1200 6.3 etc. digikey also has FC series smt. dont buy those you want radial.
              • Captain_Jon
                • Nov 2005
                • 5
                willawake... Thanks for the reply... that is very helpful.
                • Captain_Jon
                  • Nov 2005
                  • 5
                  Well I ordered the caps and just received them... Due to availability, I ordered the FC series for the 1500uf but the FM series for the 1000uf.
                  I was about to get down to installing them when I noticed that the FM series caps are bigger in terms of diameter than the YEC caps I am replacing!!
                  Being a novice at this recapping... I see that the current YEC 1000uf caps are raised on the board and not flush (whereas the 1500's are flush!)... Given that the FM caps are wider can I simply do the same and soder them in with a gap above the board?? The gap is about 1/8"...
                  • willawake
                    Super Modulator
                    • Nov 2003
                    • 8457
                    • Greece
                    should have got these 8mm ones
                    anyway no prob. i recap with 1000uf 10mm all the time. I am assuming that the YEC are 8mm. so what you do is solder some in standing up flush to the board and others you bend the leads and solder them in angled. if you have clearance problems with agp card or pci card etc you can also bend the leads and solder them in lying flat on the board.
                    dont worry there is no problem with doing that.
                    example
                    both boards still providing stable daily office duty.
                    • dragon3x
                      After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                      by dragon3x
                      Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                      power on.
                      Here are some examples :
                      (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                      switching supply area).
                      (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                      than 6.3 V.)
                      1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                      I replaced capacitors with aluminum-polymer.
                      3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                      03-21-2025, 02:46 PM
                    • iMic
                      IBM NetVista Pentium III - USI Motherboard w/ Teapo SC
                      by iMic
                      Hi folks,
                      I have a couple of IBM NetVista desktop computers from around 2000-2001. They have Universal Scientific Industrial (USI) Pro286i motherboards, 733MHz Pentium III processors, and a whole bunch of bad Teapo capacitors. One board has visibly bad and venting capacitors, while the other doesn't look too bad so far.
                      The board with venting caps works fine, while the good looking board occasionally refuses to power on unless it's left for about 30 seconds after connecting the power - even with a known good power supply. (I am however aware I'll need to check the PSU...
                      11-29-2023, 06:44 AM
                      by sam_sam_sam
                      After all of...
                      07-13-2024, 08:14 PM
                    • quickname
                      Cyberpower 1500AVR UPS repair
                      by quickname
                      I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
                      Like clockwork, I've had to replace the SLA batteries every 4 years. It was about that time and the UPS was acting like it needed new batteries... randomly shutting off with AC present, not being able to charge fully, and poor runtime when AC was removed. So, I replaced the batteries but noticed that it was not charging properly.
                      I decided to verify that the batteries were...
                      11-12-2023, 09:57 AM
                    • ctroxtell
                      Samsung UN70tu7000wxza no standby light, do I have bad capacitors?
                      by ctroxtell
                      I picked up a 70" Samsung UN70TU7000WXZA. The original owner said they were watching it when the power surged and knocked it out. I pulled the back off the TV and disconnected the main board from the power board, and the LED backlight came on, which I was told meant the power board was good. When everything is plugged in the standby light will not come on, looking at the main board BN94-17775A with a thermal imaging gun I can see one of the chips labeled 3202 is 251 degrees F just sitting idle. I found a replacement board, BN94-16115X; this board has the same symptoms, except it is a different...
                      01-03-2025, 08:57 PM
