Is it safe to ship electrolytic caps by air?
  • slerner
    • Dec 2022
    • 20
    I've read that caps can leak due to extremely low atmospheric pressure. How about in a plane's unpressurized cargo bay?
    and I gotta wonder if the Chinese govt trusts Chinese caps for their spy balloons…
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8670
    Re: Is it safe to ship electrolytic caps by air?
    Not a big deal, the low pressure effectively similar to heating them as both would result in higher internal pressure over ambient. China has satellites and space equipment too, and these have even tougher conditions than at 60k feet.
      • 30940
      dont buy into the balloon bullshit - it's a distraction from OHIO
      green lasers over hawai = https://icesat-2.gsfc.nasa.gov/
      the one in alaska = an amature meteorological balloon from near NY
      you can search and the owners are complaining about their $12 balloon being distroyed
        master hoarder
        • May 2008
        • 12164
        • Bulgaria
        It's fine.
        The caps will be OK. I've shipped caps with me in my checked-in bags many times. Also shipped computers and computer equipment with capacitors, some of which has been in use for over 10 years now. No leakage - not even from old cheapo Taiwanese capacitor brands.
        If this was an issue, we'd see a lot of laptop chargers get damaged, especially for frequent flyers... which I can tell you has never been the case. So it's OK.
        • slerner
          • Dec 2022
          • 20
          Very good point.
            by momaka
            03-12-2025, 03:42 PM
          • tony359
            Best tool to place electrolytic SMD caps on a board
            by tony359
            HI all,
            I am working on some boards where all 100+ SMD caps have to be replaced (yes, they actually went bad!). I found a workflow to remove them comfortably (two irons, pre-heater and extra hot air for larger ones on ground planes).
            When it comes to soldering them back, I add solder to one pad and then I use a plastic tweezer to keep them in the right place while I solder that leg.
            The tweezer works - but I was wondering if there is a more "dedicated" tool or whether someone has a better idea. If it was for a bunch of caps then who cares. But because...
            01-28-2024, 06:23 AM
          • Paxman_Swede
            by Paxman_Swede
            Hello!
            01-14-2025, 09:51 AM
          • captain150
            by captain150
            03-16-2025, 07:34 PM
          • Foetuss
            Gigabyte GA-6OXT :: caps question
            by Foetuss
            Good evening
            I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
            Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
            But I was also suprised about the bigger boys, which are 330µF 25V.
            Could it be they used 25V caps because they were cheaper / available at that time?...
            02-11-2025, 12:22 PM
