Is it safe to ship electrolytic caps by air?
  • slerner
    • Dec 2022
    • 20
    I've read that caps can leak due to extremely low atmospheric pressure. How about in a plane's unpressurized cargo bay?
    and I gotta wonder if the Chinese govt trusts Chinese caps for their spy balloons…
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: Is it safe to ship electrolytic caps by air?
    Not a big deal, the low pressure effectively similar to heating them as both would result in higher internal pressure over ambient. China has satellites and space equipment too, and these have even tougher conditions than at 60k feet.
      • 31090
      dont buy into the balloon bullshit - it's a distraction from OHIO
      green lasers over hawai = https://icesat-2.gsfc.nasa.gov/
      the one in alaska = an amature meteorological balloon from near NY
      you can search and the owners are complaining about their $12 balloon being distroyed
        master hoarder
        • May 2008
        • 12175
        It's fine.
        The caps will be OK. I've shipped caps with me in my checked-in bags many times. Also shipped computers and computer equipment with capacitors, some of which has been in use for over 10 years now. No leakage - not even from old cheapo Taiwanese capacitor brands.
        If this was an issue, we'd see a lot of laptop chargers get damaged, especially for frequent flyers... which I can tell you has never been the case. So it's OK.
        • slerner
          • Dec 2022
          • 20
          Very good point.
          • Perry Babin
            How do organic polymer caps compare to liquid electrolytic for reliability
            by Perry Babin
            I have a situation where a power supply is commonly abused and the 12v supply caps take a beating. They don't commonly fail but they run hot. I was thinking about going from a liquid electrolytic (Panasonic FC and Nichicon HE) to an organic polymer. The values have been 330uF. I typically use a higher-than-needed voltage to get a lower ESR. The supply is operated from 12v.
            If not organic polymer, what would be the caps that could take the most abuse?
            08-18-2025, 04:04 PM
            by momaka
            03-12-2025, 03:42 PM
          • tony359
            Best tool to place electrolytic SMD caps on a board
            by tony359
            HI all,
            I am working on some boards where all 100+ SMD caps have to be replaced (yes, they actually went bad!). I found a workflow to remove them comfortably (two irons, pre-heater and extra hot air for larger ones on ground planes).
            When it comes to soldering them back, I add solder to one pad and then I use a plastic tweezer to keep them in the right place while I solder that leg.
            The tweezer works - but I was wondering if there is a more "dedicated" tool or whether someone has a better idea. If it was for a bunch of caps then who cares. But because...
            01-28-2024, 06:23 AM
          • Paxman_Swede
            by Paxman_Swede
            Hello!
            01-14-2025, 09:51 AM
          • captain150
            by captain150
            03-16-2025, 07:34 PM
