Burned boards?
  • tz2z
    • May 2010
    • 8
    Burned boards?
    Hey guys,
    I just started soldering and this forum has been a godsend for information!
    One thing I couldn't really find though, was how to tell if you've caused heat damage to the board you are working on. I've got a terrible soldering iron (I'm in the process of finding a replacement) and I'm afraid I may have spent too long desoldering some capacitors and therefore caused damage to the board.
    Is there a way to tell based on visuals alone? I noticed that the flux was turning slightly brown which is what made me worry. It's also possible that the board I am working on has lead free solder on it, making it very difficult to remove.
    Thanks for your help!
    -Tom
  • Dgtech
    E. Technician
    • Apr 2009
    • 1462
    • Steeler
    Re: Burned boards?
    An acid brush as well as alcohol will remove the flux, even if it is brown. Sometimes it will even flake off when lightly scraped at. As far as damage to the board, I wouldnt worry unless there are pads lifing up due to direct heat exposure. Sure, sometimes it doesnt look pretty due to having to work with sub standard soldering equipment but... if it works, it works.
    Always use a leaded solder when doing electronics.
      • 31077
      Re: Burned boards?
      dont use leaded solder if your in a country that has signed up to RoHS.
      you could get sued if you do work for someone else or sell stuff.
      you dont need it anyway, unleaded solder has come a long way - it's much better than what you find on old boards.
      what country are you in?
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        Re: Burned boards?
        irrelevent for repairs.kester "44" here.
          • 31077
          Re: Burned boards?
          how is it irrelevent? try telling that to the judge!
          • Dgtech
            E. Technician
            • Apr 2009
            • 1462
            • Steeler
            Re: Burned boards?
            I dont have a clue (neither do I care) about crappy regulations of other countries. My understanding is that lead is added to solder to create a lower melting point. The flux helps the solder adhear to copper tracing or component leads. Some components can be dammaged with over exposure to the heat of a soldering iron - thus making a case for solder with lead for a quicker heat application time.
            Try proving that an LCD TV has lead solder in it for 6 replaced components VS unleaded.
            • severach
              • Aug 2007
              • 1055
              Re: Burned boards?
              I do a hundred repairs a year. HP sells a million printers a year. Who do you think the RoHS law applies to?
              Not me!
              sig files are for morons
              • tz2z
                • May 2010
                • 8
                Re: Burned boards?
                Thanks for the info guys! I don't really plan on selling my monitor so using lead solder is not a problem.
                I guess the brownish flux is not a big deal either. How about the the boards then? Is there a way to tell just by looking whether or not it is damaged?
                • Dgtech
                  E. Technician
                  • Apr 2009
                  • 1462
                  • Steeler
                  Re: Burned boards?
                  We can take a look just for kicks - if you post pictures of this repair. It wont tell us much but it wont hurt.
                  By the way, the flux is a problem due to it's conductivity. I have had failures before due to flux. This needs to be cleaned off with alcohol. Alcohol desolves it.
                  • tz2z
                    • May 2010
                    • 8
                    Re: Burned boards?
                    Just had the chance to take a photo of this.
                    What do you guys think? I'm still trying to remove the solder from the holes...it's a pain in the neck!
                      • 31077
                      Re: Burned boards?
                      looks like flux to me.
                      can you scrape it off?
                      • MXM
                        • 430
                        • Unknown
                        Re: Burned boards?
                        i had this question long ago, you just answered. Thanks!
                        @op looks like flux on that pic, and based on own experience i dont think the board is damaged by heat, to me doesnt look that bad (not yet, at least ) but thats jm2c
                        peace.
                        We don't have a great war in our generation, or a great depression, but we do, we have a great war of the spirit. We have a great revolution against the culture. The great depression is our lives. We have a spiritual depression.
                        • Dgtech
                          E. Technician
                          • Apr 2009
                          • 1462
                          • Steeler
                          Re: Burned boards?
                          The board looks ok. Clean it up an see what you got. Sometimes I use a Q-tip (cotton swab) with alcohol if I dont have an acid brush available.
                            • 31077
                            Re: Burned boards?
                            kitchen paper - like big toilet roll is good to use with IPA & such for pcb cleaning.
                            • acedogblast
                              by acedogblast
                              11-02-2024, 05:13 PM
                            • howardc64
                              by howardc64
                              Problem
                              08-04-2024, 10:36 PM
                            • Geeker007
                              Friend messed up my laptop motherboard while working on my bench
                              by Geeker007
                              Hi All,
                              So my friend was visiting and he wanted to use my solder bench to solder on some WLED circuit board. My laptop was open on the side for RAM upgrade. I know my mistake.
                              So while soldering he had too much solder on the soldering iron tip and he just shook off the soldering iron on the table itself to remove extra solder on the soldering tip and it landed on the motherboard of laptop. He then out of fear tried to remove it using solder wick and did more damage by removing some components as well. So here I am with weird situation.
                              I have not tried putting...
                              06-16-2025, 01:40 PM
                            • fabianard
                              HP 1955 - Backlight not working
                              by fabianard
                              Greetings,
                              I have a HP H1955 monitor. The monitor is obviously old (from 2005) and a similar replacement monitor wouldn’t be particularly expensive and hard to get hold on. The problem is that I'm using it for a custom built special purpose so it would be tedious and might take a while to find an exact replacement.
                              Description of problem
                              Suddenly it went black during use. When I restarted it, it stayed on for 1-2 seconds then went black again. This was repeated a couple of times. Then a burned smell came from the monitor and from that point the backlight was not...
                              07-16-2021, 11:56 AM
                            • Srdjan01
                              IPhone 12 ProMax - Thoughts of (not so young) apprentice
                              by Srdjan01
                              Hi guys.
                              I'm working on my first board reballing.
                              It's iphone 12 pro max and I made a mistake(s), but now to learn something, I hope.
                              Either I overheated the board and two ics fell off on it's own, or I clumsily took of top board and knock them off. Adrenaline was high at that moment so I do not recall best.
                              I repaired the damage by putting these components back in place. In some moment I begin tinkering about my future steps and about the fact that I have used low melt solder (138C) to put those components back. My line of thoughts was something like, if I use same solder...
                              03-17-2025, 02:49 AM
