MacBook Pro 15" A1990 Touch Bar 820-01814-01, 820-01814-A, 820-01814-B Schematic
  • silver60618
    Macbook Pro A1990 - Battery not detected after connector torn off
    by silver60618
    Hi Gang, Im working on Macbook Pro A1990, the battery connector was torn off during friend trying to replace battery. I soldered on the connector back, and created traces. The battery does charge (according to amp meter), and does power on battery only. But the signal detect line maybe done incorrectly, and the macbook shows "X" over battery icon, and "Service Recommended" on new battery
    Can somebody point me to which of these connector pins is responsible for battery detect/data line? Pin 4 on schematic had a nub on the trace, im not sure if that is important,...
    11-12-2025, 06:36 PM
  • alfredodinolfo
    MacBook Pro 2019 (A1990)
    by alfredodinolfo
    mb code:820-01827-A;
    sn:C02Z349ALVDR;
    i9 32GB Ram 1TB
    Hi, I found short on one of 6 black nand (total 1TB).
    i removed all 6 nand ( voltages all ok) and now i want to program with JC P15 but for A1990 2019 there is only 512GB configuration.
    I try A2141 1TB configurazion with TSB4228 but the position on pcb is different ( U9300 and U9400 is no stuff on A1990 but present on A2141 and U8800 and U8900 is no stuff on A2141 but present on A1990 )
    macbook with A2141 configuration run on recovery but don't complete it.​
    anyone can help me?
    05-26-2025, 09:27 AM
  • robka
    MacBook Pro 2018 - A1990 Dead - not charging - only 5V
    by robka
    my MacBook Pro 15" 2018 Touch Bar (A1990) doesn't charge anymore. Board# 820-01041-A
    I'm not experienced in diagnostics, but I want to try to solve the problem with your help, because every local shop charges around 600€ (650 usd). Which is the value of the whole Macbook.
    The Macbook was charging when suddenly the "charging sound" appeared every other second for around 4-5 times.
    After that the Macbook was dead. It isn't charging anymore.
    The USB-C Port where the charger was plugged is burned. Also The Cable and the...
    03-02-2024, 02:58 PM
  • DATATECH85
    Macbook Pro A1990 - 820-01041 Stuck at 5V / 0.02A
    by DATATECH85
    I am currently working on a Macbook Pro A1990 (motherboard 820-01041) which is not charging.
    The Macbook consumes 5V and 0.019A at USB-C. There seems to be a partial short-circuit on the PPBUS_G3H rail as I have 0V on this rail.
    I've physically separated (by removing F7000 and F7001) PPBUS_G3H and the ISL9240 charging chip to see which side the short is coming from. Removing these fuses gives me 12.6V at the output of the ISL chip (PPVBAT_G3H_CHGR_REG).
    However, I can't work out exactly why I don't have the PPBUS_G3H rail.
    Here are the values...
    07-24-2024, 06:34 AM
  • falcontech
    Macbook Pro a1990 activation locked
    by falcontech
    I received a 2018 MacBook Pro A1990 for repair, and the motherboard was replaced, presumably purchased on AliExpress. The motherboard's activation is blocked because the previous owner didn't delete it. Does anyone have a solution to this problem? I called Apple, and as expected, they asked me to activate the process with proof of purchase for the original computer, which I find very difficult, so the proof of purchase from AliExpress will be of little use. Any suggestions? Thanks.
    09-29-2025, 06:57 AM
