Go Back   Badcaps Forums > General Topics > General Capacitor Questions & Issues
Old 09-22-2007, 10:47 AM   #1
Krankshaft
Krankshaft's Avatar
City & State: New Jersey, USA
Default Dead Samxon GFs
So I go to a customers house last week and picked up a Gateway LCD monitor that they told me popped and shut off and ever since then it would come on for a few seconds then shut down.
So I open it up and to my suprise there are bulged Samxon GF series caps inside .
I didn't take a picture before removal but heres a pic of the offenders.
So I replace the caps with Panasonic FCs and viola the monitor is back in business.
The fault detection circuit was shutting down the PSU to prevent damage due to the faulty caps.
Now I understand LCD supplies run rather hot but come on this monitor barely made it to one year. And NO it hasn't been run 24/7 for that year either.
Is the GF series just a dud or something?
Krankshaft is offline   Reply With Quote
Old 09-22-2007, 11:14 AM   #2
Newbie2
Newbie2's Avatar
City & State: Halifax, NS
My Country: Canada
Line Voltage: 120VAC 60Hz
I'm a: Complete Noob!
Default Re: Dead Samxon GFs
See this thread: http://www.badcaps.net/forum/showthread.php?t=4116
Big Pope, who sells SAMXON caps on this forum, says that the GF series is an older series of caps and newer series of SAMXON caps are more reliable than the GF series of caps.
My gaming PC:
AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
ASUS M4A77TD AMD 770 AM3 Motherboard
PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
ASUS Xonar DG 5.1 Channel PCI sound card
Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
Antec Three Hundred Mid-Tower Case
Microsoft Windows 10 Pro 64-bit
Microsoft Windows 7 Ultimate SP1 64-bit
Newbie2 is offline   Reply With Quote
Old 09-22-2007, 03:23 PM   #3
Topcat
The Boss Stooge
Topcat's Avatar
City & State: Salem, MO
My Country: United States
I've seen those dead in the very same LCD monitor inverter. I was also told they're an older series. Also after you recap it, take note of how hot that inverter gets, I think that's also an attribute to the failure.
<--- Badcaps.net Founder & Owner
Badcaps.net Services:
Premade Capacitor Kits
Badcaps.net Capacitor Master List
Motherboard Repair Services
If you've come here in search of replacement capacitors or repair services, please use the links above.
http://folding.stanford.edu/
Team : 49813
Join in!!
Team Stats
Topcat is online now   Reply With Quote
Old 11-01-2007, 09:27 PM   #4
kk517
My 21" Gateway monitor stopped working last week.
Thanks to this thread/forum I now know the problem.
Any recommendation of a handy person(in GTA, that's Toronto, Canada) who will replace these caps for under $100?
kk517 is offline   Reply With Quote
Old 11-02-2007, 08:31 AM   #5
Per Hansson
Per Hansson's Avatar
City & State: ----
My Country: Sweden
Line Voltage: 230v 50Hz
That's a very easy recap job
Single layer PCB, you could ask any TV repair shop or similar to do the job, just make sure they put in caps from one of the 5 major Japanese brands! (so you don't have to go back in 6 months...)
Old 11-02-2007, 01:35 PM   #6
gonzo0815
City & State: Germany
That exactly is the whole problem with the typical TV repair shop. They are using crap caps as they either do not know it better or they just can`t make it economically for a reasonable price.
gonzo0815 is offline   Reply With Quote
Old 11-02-2007, 07:18 PM   #7
Krankshaft
Krankshaft's Avatar
I think the problem is that they simply go to their distributor or order online and take whatever they have. If its the right uf value and WV its fine.
I personally use Chemicons KMG and KME for general purpose applications and Panasonic FCs for low ESR.
Make sure the caps are replaced with Low ESR 105 C temperature rating caps and not general purpose caps. The Panasonic FC series is a good one and I believe the FCs are a non-aqueous electrolyte unlike the FMs.
Any main brand is fine:
Rubycon
Panasonic
Nippon (United) Chemicon
Nichicon
Samxon
Check out the bad caps sticky thread just to get a feel for the names of the bad ones.
Old 11-03-2007, 12:37 AM   #8
severach
City & State: Michigan
I'm a: Hobbyist Tech
You buy them and take them in. Be prepared for the guilt trip for asking them to installed customer supplied parts.
severach is offline   Reply With Quote
