Are Nichicon HM's still bad?
  • Maxxarcade
    • Jul 2006
    • 973
    I know that there was a time when the Nichicon HM and HN series caps were bad due to over filling... Are they still having this problem today? My new Gigabyte board has Rubycons on the VRM input and Nichicon HM's on the output. My last board did also, and those are still good.
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Are Nichicon HM's still bad?
    should be fine. intel were using them on later boards also and we did not see probs.
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16956
      I'd still be leary....
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        Dennis?
        • Spacedye69
          • Nov 2005
          • 698
          • US
          I use newer HMs and they have been fine so far.
          • dungbeetle
            • May 2007
            • 94
            Originally posted by willawake
            Dennis?
            I got it! The guy who sang...
            "I'm an a**hole"
            Regards,
            db
            • leekh
              • Jan 2007
              • 24
              i understand that there is a massive bad batch of nichicon HM and HN series during the period of 2001 to 2003. Is it still considered bad for these series that is found in products of 2006 and 2007?
              i am a bit worred because my 7-month old MSI motherboard (K8N Diamond Plus) has 2 to 3 of nichicon HM(N) capacitors on it. The rest are Sanyo OS-CON SEPC polymers on the VRM output, Rubycon MBZ series on VRM input, Panasonic FMs on the almost everywhere on the motherboard, 3 U-Chemicon KZGs between the 2 PCI-Express X16 slots and also 2-3 small G-Luxons without vents.
              • leekh
                • Jan 2007
                • 24
                I have checked on the 3 Nichicon HM(N) caps on the motherboard, they are all rated 470uF/16V. Will these caps be ok in the long-term? I have spend quite a bit on this ultra high-end motherboard.
                someone please enlighten me. thanks in advance.
                • DrewPhillips
                  Capacitor Diarrhea - Nichicon PL Series
                  by DrewPhillips
                  Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
                  The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
                  03-02-2025, 10:18 PM
                • nick3092
                  Mid/late 80's Nichicon Yellow Caps
                  by nick3092
                  I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
                  08-28-2022, 03:56 PM
                • chth96
                  Is there datasheet for nichicon LXJ series?
                  by chth96
                  I want to calculate capacitor ESR referring to below guide.
                  https://forum.digikey.com/t/calculat...-from-tan/2633
                  I must find out dissipation factor(Tan(δ)) for nichicon lxj series(6.3v 1500uf,25v 1000uf ,10v 2200uf)
                  I finally found out datasheet which has all series of nichicon capacitor.But unfortunately, It removed old nichicon capacitor.
                  Is there anyone who still has old nichicon datasheet which has information of LXJ series?
                  11-20-2022, 08:11 AM
                • chth96
                  Is there any datasheet for nichicon RT(M) series?
                  by chth96
                  A few days ago,I destroyed one of my japanese retro game console by pluging it to 220v outlet.
                  https://www.badcaps.net/forum/troubl...e-been-blew-up
                  and I finally fixed​ this retro game console by soldering varistor and glass fuse.
                  But I noticed that When I measure voltage of PSU's 5pin connector, it is 8.80-9.07v, 5.13v,3.40-3.48v,GND,GND instead of its rated voltage of 9v 5v 3v GND GND.
                  I have spare console...
                  11-28-2023, 03:36 AM
                • spiros.p
                  EV dsp,replace the nippons lxz with nichicon fw ?
                  by spiros.p
                  Hi guys.I have two EV dsp processors and before two years i do full recap to both. The units have before recup thousands hours running.On output input coupling caps (16 pieces) i solder nippon lxz series 100mf 63v (this time i don't have other stock) i know is low esr caps.Last week have found and order nichicon fw standard audio series.Is a good reason to replace the nippons lxz with nichicon fw ? The units get better sound? Or get worse?Thanks for any advice.
                  12-19-2023, 12:26 AM
