Dell e172FPb Actual Schematics
  • lcdman
    TinkerTech
    • Nov 2010
    • 232
    • U.S.A.
    I need ACTUAL circuit schematics for a Dell e172FBb inverter/power board. I've seen some but they never have all the parts in them? I have the following board revision numbers that I'm looking for at this time.
    48.L9202.A01
    48.L9202.A02
    48.L9202.A10
    48.L9202.A11
    48.L9202.A12
    48.L0J02.A12
    These are out there somewhere! I just haven't located them yet. I've checked and replaced all bad caps,transistors. None of the resistors appear burnt. And all of the diodes and the PF751 fuse check good. But I' still not getting the correct voltages at the union connector between the inverter/power board and the logic board? Any help that this site could provide would be awesome!
    lcdman
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Dell e172FPb Actual Schematics
    Can you give an example of incorrect voltages? Are the voltages fluctuating or steady?
    Also, what are the voltages at the dual diode pack/Schottky?
    --- begin sig file ---
    --- end sig file ---
    • EGuevarae
      • Nov 2008
      • 1336
      I agree. More info, and actual readings are needed.
      As for actual schematics,that's a hard one .....
      • ASUS ROG Maximus IX Code
      • Intel Core i5-7600K 3.8GHz
      • Windows 10 Pro x64
      • GeForce GT1050
      • lcdman
        TinkerTech
        • Nov 2010
        • 232
        • U.S.A.
        I have a pin-out of a working board at the connection point between the inverter/logic boards. Hopefully I posted it correctly? The voltages drop and don't recover. As far as "dual diode pack/Schottky", I don't know which part on the board you're referring too? Maybe you can tell me a part # on the board or even a picture of what you are talking about?
        Thanks Again.
        lcdman
        • jetadm123
          • 2169
          Thanks Again.
          lcdman
          It would help immensely if you could post photos of your board. That way, members can point exactly to the component they want you to test. There were many different versions of power supplies used on the E172-173 series of monitors and members will not spend too much time looking for pictures for you.
          • EGuevarae
            • Nov 2008
            • 1336
            Sorry for breaking the no-inline pictures rule, but ....
            • GeForce GT1050
            • retiredcaps
              • Apr 2010
              • 9271
              Just so we are clear, the units you have listed is mvac. Is that millivolts AC? If not, what is it?
              Generally, on the connectors between the inverter and logic board, we are measuring DC V. Some board will have the voltages printed right on the PCB.
              The "dual diode pack/Schottky" is usually 3 legged IC mounted on a heatsink.
              • sabre504
                • May 2010
                • 449
                • United Kingdom
                Not sure if this will help its the only one i have but there are a lot of revisions on this unit so this one may not be correct
                • lcdman
                  TinkerTech
                  • Nov 2010
                  • 232
                  • U.S.A.
                  The readings I got at CN701 were in millivolts AC! I checked all electrolytic caps. And replaced where they were bad. I replaced all (4) C5707 and the (2) FU9024N transistors. I even checked the main fuse and PF751. I also checked all of the diodes. And all of the other transistors on sinks as well as just regular transistors without sinks. The only things that I didn't finish checking were the resistors as seen in the one A10 picture. I fixed one e172FPb with replacing just the (4) C5707 and the (2) FU9024N and PF751 fuse. And its still working well several months later. But before that monitor I never tinkered with an LCD monitor before. So I have alot more to learn thats why I'm here on your site!
                  I tried enclosing 12 pictures front and back of all the inverter/power boards that I'm currently working on but they were missing a security something?
                  I tried sending them compressed. Any suggestions?
                  Thanks Again,
                  lcdman
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    At that connector, we want to measure DC V. Typically readings for Benq style boards are 5V and 12V DC.
                    1) Post clear focused pictures after reading
                    https://www.badcaps.net/forum/showthread.php?t=1868
                    2) Please do not post pictures inline as they slow down the loading of pages.
                    3) For best picture quality and clarity take your boards to a window on a sunny day, turn flash off, and use macro mode. Take a top down view of all your boards (front and back). Make sure the photo is legible so that we can read the PCB printing clearly. A shutter speed of 1/125 or faster will produce nice clear focused pictures. Try to get a photo that is 2000x2000 resolution or as close as possible.
                    4) Here is an example of the pictures we want.
                    https://www.badcaps.net/forum/showpos...94&postcount=1
                    edit: 5) The max size for each pictures is 2MB.
                    • lcdman
                      TinkerTech
                      • Nov 2010
                      • 232
                      • U.S.A.
                      I didn't see you tell me why my pictures needed a security thing a ma gig. I have pictures of the revision number and the component side of the boards. Can I post all my pictures using the insert image button above? I did try measuring DC at the union between the two boards. I went from left to right. Measuring top and bottom pins as a set all the way across. Is there a different process for measuring the voltages at that point? I'm not a technician but have been tinkering with electronics for awhile. Its possible that I checked a component incorrectly! Please tell me another way other than risking injury using my Fluke with a live circuit.
                      Thanks As Always,
                      lcdman
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        Use the manage attachments button to upload pictures. It is documented in the FAQ link I posted above.
                        To measure DC voltage, put your fluke on DC voltage. Put all your boards together with the ground screws back in. Put your black lead into the COM. Put your red lead into the Volt.
                        Put your black probe onto a ground screw near the connectors. Put your red probe on each connector. All these voltages on the connector are typically less than 19V and will not cause a problem for Flukes.
                        • lcdman
                          TinkerTech
                          • Nov 2010
                          • 232
                          • U.S.A.
                          I still can't upload all 12 of my board images! I don't have a URL to do the images either! I just keep getting a message about a missing security token? I got a image to upload once. How do I get this elusive security token? Do I understand you correctly, each of the ten pins at CN701 has a voltage DC?
                          I'll try to measure each pin. From the closest ground screw to each of the ten pins. What kind of voltages DC should I find at pins 1-10? Thanks for the advice!
                          Have A Great Day,
                          lcdman
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            We don't need 12 pictures. I don't manage this site, just upload one board picture (top view).
                            I have never heard of anyone requiring a security token. All you have to do is use the manage attachments button to upload. Just upload ONE picture. Pay attention to the 2000x2000 resolution and 2MB limit for each picture.
                            Some of the pins will be ground, some will have DC voltages, some pins are used for backlight on/off, dimmer adjustment.
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              BTW, we should ask you what is the actual problem that makes you want to measure the DC voltage at the connectors? Please describe in as much detail as possible.
                              • torin3
                                • Aug 2009
                                • 178
                                How are you trying to upload 12 photos? There are only 10 slots for upload locations in the manage attachments window. You can't put in 12. If you really feel you need 12, try 6 in one post and 6 in another. Also, what file extension are these photos? What size are the photos?
                                • lcdman
                                  TinkerTech
                                  • Nov 2010
                                  • 232
                                  • U.S.A.
                                  Hello Yet Again,
                                  I smoked a logic board. Since then I've been trying to get a working monitor. Maybe there was a short? I think that the pictures will work now. Sorry for the delay. I said that I was new to this site! Thanks again for all your wisdom.
                                  Till Next Time,
                                  lcdman
                                  • PlainBill
                                    • Feb 2009
                                    • 7034
                                    Hello Yet Again,
                                    Till Next Time,
                                    lcdman
                                    You don't follow instructions very well, do you? Those pictures are too low resolution to be useful. It's just as well you also omitted pictures of the bottom side of the board.
                                    You 'Smoked a logic board'. HOW did you smoke it? And why are you posting pictures of the power supply?
                                    Here are my instructions: Read the suggestions on attaching pictures. Take good pictures of the top and bottom of one of the power supplies. In your next post explain EXACTLY what you are trying to accomplish. If requested, attach the pictures.
                                    A lot of the people here started off knowing next to nothing about repairing monitors before they found this board. I am one of them. Some knew very little about troubleshooting electronics. Most knew a little.
                                    That doesn't matter. We are willing to help you, but you must also provide clear and correct information before we can help.
                                    PlainBill
                                    • lcdman
                                      TinkerTech
                                      • Nov 2010
                                      • 232
                                      • U.S.A.
                                      Hello All,
                                      I hooked up a "power supply" to a logic board and then to the screen, etc.
                                      Plugged it in and the logic board started to smoke. So I very quickly unplugged the PSB and went back to the drawing board. Like I stated before the PSB probably had a short after attempting to repair loose C5707 and FU9024 that were found after dissembling this monitor in the first place. So then I went about checking and replacing all the (4) C5707, the (2) FU9024N and the radial caps that had possibly failed. After doing those redos I thought that it would be better to check the voltages before ruining another logic board, they are too expensive to replace. Since that attempt I then fixed the other 5 boards that I tried to post pictures here. If you need more info, I know you guys will tell me!
                                      Have A Good One,
                                      lcdman
                                      • PlainBill
                                        • Feb 2009
                                        • 7034
                                        Hello All,
                                        Have A Good One,
                                        lcdman
                                        NOW it's clearer. Good idea NOT trying another logic card on that good power supply / inverter (PS/I) card. Lots of people would have blown two or three logic cards.
                                        Let me verify this. You have 5 good PS/I cards, 5 good logic cards, and 6 good panels. Is that correct?
                                        If it is, the most likely cause is excessive voltage out of the power supply. You can test it without anything hooked up to the card (except a power cord). Check the voltages on the connector to the logic card. If you need help idetifying the points to test, attach good pictures (as close to 2000 x 2000 as possible) and we'll identify the proper points.
                                        I would suggest that a good LCD panel is probably worth more than the cost of repairing the power supply and replacing the logic card.
                                        PlainBill
