a sudden rash of fsp,fortron,sparkle,ect psu's with dead fujjyuu(sp)? caps
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    in the last 3 weeks i have gotten 14 350w fortron,fsp,sparkle,ect units in as dead.
    each has the fujjyuu caps leaking.
    the teapo's look and test fine but i change them for pm.
    i have seen a few in the past but now we are seeing lots of these here and at the shop.
    at least these are worth recapping!
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: a sudden rash of fsp,fortron,sparkle,ect psu's with dead fujjyuu(sp)? caps
    aw not fortron
    how old are the units?
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      one is less than a year.
      i remember the store getting the case in new.its got a strange vent/fan scoop on top.
      • Chris1992
        • Apr 2005
        • 561
        glad my 1 Sparkle 250W (2001) has good Fuhjyyu's. 2 PowerMan (Fortron OEM) PSUs (both 250w) in comps I am responsible for (2002) also have good Fuhjyyus.
        The great capacitor showdown!
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          jeez, they are not fortron bluestorm 350w are they?
          forton is oem for OCZ!
          here we got
          fortron 350w - 38 euro
          fortron 350w bluestorm - 55 euro
          fortron 400w bluestorm - 76 euro
          i have Fuhjyyu in a few but i am yet to come accross these uber shite versions like in the antecs previously posted.
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            my guess is these caps are coming to the end of their (short) lifespan.
            i see lots of bad fujjyu caps in other devices so i doubt there is such a thing as a good one.
            • linuxguru
              • Apr 2005
              • 1564
              Channel-Well CWT-150 FATX from a Shuttle SV24 SFF - loaded with Fuhjyyus. This is a 1U/FlexATX sized unit, so everything is crammed tightly inside the case - there are a bunch of caps located beneath inverted L-shaped heatsinks on the rectifiers, making replacement difficult. Most of the secondary-side caps are 10 or 8 mm dia, limiting the capacitor choices.
              I used:
              2 x Panasonic FC 1000/10 on the +5v rail
              1 x Panasonic FK 1500/6.3 on the +3.3v rail
              1 x Panasonic FC 1000/10 on the -5v rail
              Left unchanged: Several 470uF Fuhjyyus. One 1650uF/16v Fuhjyyu in 10mm diameter on the +12v rail - replacements in good brands in that size are pure unobtainium. Anyway, the 12v rail is not heavily loaded on the Socket-370 SV24 system - there's only a single DVD drive and hard drive installed.
              Burn-in testing after recapping shows the +5v rail rock steady at 5.02 and the +12v at 12.12 with minimal drift. I'll take my chances - none of the remaining Fuhjyyus shows any signs of trouble yet.
              Just for reference - what are the replacement choices available for 1500/16 or 2200/16 in 10mm dia.?
              • Oklahoma Wolf
                • Dec 2005
                • 353
                I hate those things - my 420W has three of those needing replacement, and only 10mm will do. I emailed CWT's US branch and they told me I could use higher value caps, but I've been too scared to try it. So, that PSU is now in very limited use powering hardware I don't care about anymore with a somewhat high 5v rail.
                • Newbie2
                  • Sep 2005
                  • 885
                  There are Panasonic FC 1500uf 16V caps at Digikey in 10MM diameter.
                  http://www.digikey.com/scripts/DkSea...=34483&Site=us
                  My gaming PC:
                  AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
                  ASUS M4A77TD AMD 770 AM3 Motherboard
                  PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
                  G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
                  TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
                  WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
                  ASUS Xonar DG 5.1 Channel PCI sound card
                  Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
                  Antec Three Hundred Mid-Tower Case
                  Microsoft Windows 10 Pro 64-bit
                  Microsoft Windows 7 Ultimate SP1 64-bit
                  • linuxguru
                    • Apr 2005
                    • 1564
                    Thanks, the Panasonic FC 1500/16 10x30 seems to be a good substitute - still need to check the clearance to the heatsink above it - may be a close fit.
                    • Newbie2
                      • Sep 2005
                      • 885
                      That was a mistake, that was P10254-ND (12.5MM) and it was supposed to be P10255-ND (10MM).
                      http://www.digikey.com/scripts/DkSea...=34484&Site=US
                      My gaming PC:
                      • kc8adu
                        • Nov 2003
                        • 8832
                        • U.S.A!
                        the 470 ones are likely on -12 or +5 stby.change them now as they go bad too.
                        had a system in here that took a 10 min.warmup to repond to power button.+5 stby was 8.3v with 4v p-p trash! lucky it didnt kill the board.
                        • Newbie2
                          • Sep 2005
                          • 885
                          We gotta now the size (diameter, etc.) of the 470uf caps too. I find it to be easier to find replacements with this little imformation.
                          My gaming PC:
                          • Oklahoma Wolf
                            • Dec 2005
                            • 353
                            I just pulled apart a CWT ATX-375 - the Fuhjyyu 470's in there (all 3 of them) are 8mm diameter. Didn't pay close attention to the length - this one has plenty of room.
                            Two need replacing in this unit - it's a friend's PSU, so I'm recapping everything and making a gift out of it.
                            • Mustang
                              • Dec 2003
                              • 203
                              Digikey also has nichicon 1500uf HE 16v 10mm. P/N 493-1529-ND
                              I had the same 1650uf caps and was lucky enough to wrestle in a panasonic 1800uf 25v FM 12.5mm cap. P/N for that is P12381-ND.
                              • linuxguru
                                • Apr 2005
                                • 1564
                                There are at least three Fuhjyyu (M) P7 470/10 8x13.5 - one each on +5v, +5vsb and -5v. I've now replaced them all with Panasonic 1000/10. There's also a Fuhjyyu (M) P10 470/16 8x14 on -12v, where I was able to squeeze in a Chemi-con 470/25.
                                The Fuhjyyu 470/10 and 470/16 are almost identical in size and appearance. There's also a Fuhjyyu (M) P10 1000/10 (blue sleeve) in size 10x20, as well as a Fuhjyyu (M) P7 1000/10 (black sleeve) in size 8x16. Go figure - I can't think of better reasons to avoid Fuhjyyu.
                                • kc8adu
                                  • Nov 2003
                                  • 8832
                                  • U.S.A!
                                  i ordered some 470@25 panasonic fc for a cnc job and found them also good for these 470@16 fuhjjyu.
                                  8x20mm iirc.
                                  • Newbie2
                                    • Sep 2005
                                    • 885
                                    Here's a replacement for that, 8MM diameter too.
                                    http://ca.digikey.com/scripts/DkSear...=54636&Site=CA
                                    My gaming PC:
                                    • Oklahoma Wolf
                                      • Dec 2005
                                      • 353
                                      Cool
                                      I'm about to post pics of my CWT 420W in the pictoral thread - this one's going to be a nightmare to recap. It now has 4 bad Fuhjyyus - two 1650@16v, 10x25mm; one 1000@10v 8x20mm; and one 3300@10v 13x22mm. Most of these have no height restriction, but one of the 1650's must be less than about 28mm tall. There are also two Capxon 3900@10v 13x22mm I plan to replace as well, though they look ok.
                                      To make things infinitely worse, there's a vertical PCB glued and soldered in there that will need to be removed to gain access to some of the caps. And the PCB is dual layer. Fun times ahead
                                      • linuxguru
                                        • Apr 2005
                                        • 1564
                                        A good replacement for the 3300/10v Fuhjyyus/Capxon is the Nichicon PW(M) 3300/10 12.5x31, if you have the space. They're rated for 105c/7000 hours endurance, 0.025 ohm ESR at 20c, and 2.3A ripple current. My favorite caps for the +5v rail anywhere - PSUs, motherboards, etc.
                                        • esqmooo
                                          HP Elitebook 845 G8 dead, only caps lock flashing 7 times. Charging light always on
                                          by esqmooo
                                          Hello everyone.
                                          This is my development machine. I've been using it since two years and half without any problem except sometimes it wouldn't wake up from sleep.
                                          Lately the issue became more frequent and powering it up would take few seconds to show the POST screen.
                                          Then the computer refuses to power on at all. Now only the caps lock button flashes 7 times then stops. The charging light is always on whenever a power source is connected (battery or charger).
                                          I tried long pressing on the power button, after several seconds it would go off then when the button is released...
                                          03-11-2025, 03:57 PM
                                        • eryjus
                                          Heathkit IO-4205 Power Supply Caps
                                          by eryjus
                                          First, I am a complete noob with high voltage stuff. I'm learning, but I need help by someone looking over my shoulder.
                                          I recently came into posession of a Heathkit IO-4205 5MHz Dual Trace Oscilloscope. The documentation is copyright 1978. I'm told it works.
                                          I opened it up to check the caps before I applied power, and found the following black caps and wanted to know what they were. They are on the power supply board. I was able to read the name and model and came up with, "Nytronics 162J-1, 0.1uF, 20% tolerance, 2000VDC."
                                          05-10-2023, 11:21 AM
                                        • Kiwi Viking
                                          HP Elitebook 855 G8 all of a sudden does not power on. 7 flashes of Caps lock and Number lock prod ID 4X5S2PA#ABG
                                          by Kiwi Viking
                                          HP Elitebook 855 G8
                                          Product ID:4X5S2PA#ABG
                                          Motherboard M53301-601.
                                          Hi Gurus, I am wondering if someone might be able to help. I purchased recently this used computer that otherwise looks in mint condition. I worked for 1 week, until one morning I shut down the computer using the power off commands in windows. There was no warranty. This was purchased for my teenager for use at school.
                                          When I went to start the computer up in the afternoon, all the keys lit, but the computer didn't POST. Then the next thing I tried (pressing the power button) resulted in only the...
                                          03-01-2025, 01:05 AM
                                        • captain150
                                          Help with switching power supply caps
                                          by captain150
                                          I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
                                          I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...
                                          03-16-2025, 07:34 PM
                                        • Foetuss
                                          Gigabyte GA-6OXT :: caps question
                                          by Foetuss
                                          Good evening
                                          I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                                          Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                                          But I was also suprised about the bigger boys, which are 330µF 25V.
                                          Could it be they used 25V caps because they were cheaper / available at that time?...
                                          02-11-2025, 12:22 PM
