Hi
I was given a 42" LCD L42WD22 from a friend to see if I could fix it... I have had no luck thus far. Here's the breakdown.
Symptoms
- No Picture at all (black screen) when TV is turned ON
- No clicking or hissing noises when TV is turned ON
- TV powers ON (Green LED Constant)
- Sound works
- No standby LED when TV is OFF (not sure if this model has a standby light)
Tests I've Run
- Visual check for bad capacitors was negative (no bulging or popping)
- Visual check for cracks in circuit board was negative
I am very new to LCD repair and only attempted this because I have successfully repaired my Samsung LCD by replacing the bad capacitors I found.
I am going to be checking for bad solder (cold solder) joints but I'm not sure where to focus my search.
Has anyone else had problems of this nature?
Symptoms
- Sound works
Tests I've Run
