I have a motion detector that uses 3 C cells for the receiver and chime. It has a plug that is labeled 4.5 V. I tried a 5 Volt 3 Amp power supply with no success. The receiver works and the LED lights up in response to movement near the motion detector but no chime. I did some rewiring (thicker gauge wires) and can get the chime to ring SOMETIMES. I think the receiver chime draws more amps than I am providing with the power supply I have.
I found some nice boards that will provide regulated 4.5 volts but are only rated at 2 amps. I have a 6 amp 12 volt supply and was thinking of using two boards with both boards inputs wired in parallel and both outputs also wired in parallel. Will this work?
See attachment.
See attachment.
