I got this thing with a destroyed fan (The plastic holding the shaft to the blades broke) and the thing had no power, not even 5VSB. I pulled it to inspect it. Fuse wasn't blown, strange....
I looked at the soldering side, which was of horrible quality. I found a broken joint on the PFC coil, and a cold joint on the startup resistor. Plugged it in, still nothing....
Checked bridge rectifier, PFC silicon, all diodes/resistors on the primary, and then noticed the cracked PFC film cap. Replaced that with a better spec'd part. Still nothing. I pull it and throw it into another PSU chassis, and it fired right up! I figured it must have been some of the input filtering components on the small PCB before the fuse, so I took a similar one off another PSU and threw it back in the original chassis. No power, not even 5VSB.......WTF!! So then I pulled the AC plug and found that the glue had hardened on one of the AC pins. Wow! I guess it just shows not to over-think things, which I tend to do too often.
I recapped it because all the caps were Ejicon (They all tested good), upgraded the bridge rectifier from 4A to 6A, mainly because the BR, PFC film cap, and fusible resistor were all packed in there too tight. Installing the bridge rectifier moved over to the side like that gave the other two components room to breathe, and at least they're not touching each other anymore.
I find it interesting at their choice of heatsink sizes. Biggest on the PFC silicon??? I also could not believe that they didn't put a plastic sheet between the toroid coils and output rectifiers! I installed one.
