Apple Macbook pro A1286, wery slow
    Hello.
    Have this Apple Macbook Pro A1286 that have bad balls under GPU. After reball image come ok but whole system is WERY slow. it is slow even with another system. any help in this?
    Re: Apple Macbook pro A1286, wery slow
    flash the bios, maybe bad dump
    post the whole motherboard code; maybe i have a dump file
      i have the same problem ,
      after reflow , the sistem is very slow , and fan is at full speed
      any help ?
        Any help please
          Sounds like a thermal sensor short.
          ASRock B550 PG Velocita
          Ryzen 9 "Vermeer" 5900X
          16 GB AData XPG Spectrix D41
          eVGA Supernova G3 750W
          Alienware AW3423DWF OLED
            how can i found the sensor ?
              There is a disk floating about ATT I think its called. Boot to that and it checks all the sensors.
                here is the temperature, sistem have like a lag, and fan full speed
                can give a link for this program ?
                board is 820-2915-b
                graphic 216-0809000
                  board is 820-2915-b
                  graphic 216-0809000
                  I'm out at the moment but I'll try and remember to post when I'm back. It was a torrent if that helps at all.
                    thats seems bad gpu KTM , specially macs are week in that behaviour , usually once gpu start to fail all internally start to fade out as well , the best option you got here is to replace the gpu KTM , also make sure you insert same chip , if its 128 bit USE 128bits , or you might have future issues
                      what KTM means ?
                      i make reballing to chip , and the same problem . you belive that i need to change gpu ?
                        yes , indeed gpu chip can slow down your system once they are in life end . macs are expert on thaat issue , gpu replacement solve in the moment this issue !
                          KTM =KTMMOTOCROSS (user in the forum)
                            im mad, becase before reflow, or reballing, the fan works normal.
                            or how can i modify to run only processor graphics ?
                              yes , you killed gpu ,
                                u need to change the gpu; highpulse is right
                                  thats why have a lag and fan full speed.
                                  cannot be the memorys ?
                                    fan is controlled by smc. have u done a pram reset after reflow or gpu reballing ?
                                    when a pc is slowind down generally it's intel chipset. (had an hp notebook that was slowing down and after a day it went dead. after reballing these small intel bga it went back ok to normal.
                                      yes, try reset nvram ,
                                      now i reset pram ? tks
                                        command +control + p +r and press ON button , but still leave pressed command control p + r until it restart again , once it restart stop pressing the keys
