Hmm - no fuses or anything obvious with it all connected and switched on
can you test what I think may be two voltage regulators.- bottom left of the pic. ( Pictures are improving )
Read this, by retiredcaps, on how to test. The bigger one if you post the part number I will check it is a regulator - or you can.
Not certain - they generally fail by producing a steady but incorrect voltage
or no voltage at all. I know that having a failing cap connected to a VR can
produce bad results - I would hope that they are ok and see what replacement caps do. What we need to find is more voltages. A couple of things to try would be test the connector pins on the power supply without the main board connected. Also and you will need to be careful check the voltage on the start up cap - at one point I though it was a bit rounded but then decided it was just the picture. It is a 50v one between the heatsink and the yellow transformer. So you will need power on and meter on v200dc -obviously it should not be more than 50vdc you can measure topside if you can get at it or underneath. Set it all up so you can measure then switch it on careful not to touch the BIG caps.
The cap that is between the heatsink and the yellow transformer is supposed to be 50v 33uF and when tested it is ranging between 9.5 to 14.3V. Well I guess it's a bad cap. Can the cap be replaced with a different one as I don't have one that type of uF.
It depends on how it is used, if it is used for timing circuits, then No. If it is used for simple filter cap, then you can use it for now just for testing the function of the circuit.
Higher voltage is OK to use as long as the body still fit the board since higher voltage cap will be bigger than the lower voltage cap with the same capacitance rating.
Good to get a few jolts early in your introduction to electronics- makes you more careful
if not dead Perhaps use an RCD device.?
Pity it didnt help - back to the drawing board - when you say same result do you mean the
varying voltage on the cap? At least its another voltage.
Can you check the voltage across the two big resistors on the main board.
Perhaps also test the resistance - Power OFF meter on ohms ???
Type in Hobby Resistance into your browser and you will find a site that
gives you the resistance colour band guide.See on there what resistance to expect and set your meter range accordingly.
