One of my L1955 monitors has just started to not wake up from power save or sleep. I have been able until now to simply either switch off or remove the power cable then re-power which will make it work again until the next power save or sleep time. The green power led lights all the time (dims slightly when the display appears) then the backlight appear to turn off and the power led stay on. It now also just perodically dies, still with the green led lit with text visible by torch.
I had another one which totally burnt something out on the power board (see attached P107490) and i swapped the power board out of a working display into that and it worked perfectly. I've since swapped the power board from this one into that and get the same problem so assume it is something wrong with that board and not anything else.
Does anyone have any ideas where i should start? The CAPS as far as I can see are ok.
Photos of boards attached.
