What Exactly Is a Capacitor?
  • PeteS in CA
    • Aug 2005
    • 3581
    • USA, Unsure of Planet
    Here is a very informative article, titled What Exactly Is a Capacitor? It give some history and discusses the common types. The section on ceramic types gives good info on temperature coefficients.
    Here is a technical information document from AVX, describing monolythic ceramic caps and their manufacture.
    PeteS in CA
  • arneson
    • Sep 2005
    • 1267
    Re: What Exactly Is a Capacitor?
    I love the history stuff.
    Like when the first capacitor had gold and was measured in Cubits.
    Maybe one of those Leydon jars could cool my Proc and filter the V supply at the same time.
    Jim
    • MORETTIGIAN
      by MORETTIGIAN
      Title:
      Description:
      Procedure performed:
      - Removed backplate
      - Reapplied thermal compound
      - Reassembled card
      09-18-2025, 12:14 PM
    • chth96
      by chth96
      03-09-2024, 10:03 PM
    • NuclearSpartan
      Samsung C32HG70 - Blown Ceramic Capacitor (CP813)
      by NuclearSpartan
      I'm new to this, so I apologize for not providing enough details. Is there anything else I need to mention? I'm trying to learn more about electronic/board repairs and hopefully fix my own.
      The only visible issue on my board is one capacitor, CP813, which appears to be labeled R 221k 2kV (possibly obsolete to B 221k 2kV now). My monitor hadn't shown any prior issues, although it is a few years old. Just before the capacitor popped, there was a high-pitched squeal for 2–3 seconds.
      I don't see any other visible damage anywhere else on the board....
      11-14-2024, 02:32 PM
    • rictechie
      smd ceramic capacitor use in iphones
      by rictechie
      is there a brand of smd ceramic capacitor use in iphones? or they are generics
      07-26-2024, 08:28 PM
    • Prolog
      by Prolog
      12-01-2024, 08:27 PM
