New electronics repair tool. Strong Power supply HR-1520.
  • electroman5946
    • Jul 2012
    • 11
    • US
    New tool I received from AliExpress. It's a mini power supply and it can also make it easy to repair shorted motherboard. Has any one heard of this?
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: New electronics repair tool. Strong Power supply HR-1520.
    There are a couple of threads of them here yes, I can't off the top of my head remember where they where discussed though.
    • Holden53
      • Oct 2022
      • 4
      Hi - and I find that interesting - if you have a link to this on Ali - let me know - I do bench work and usually have an ATX power supply laying around but this looks like a good idea.
      Thanks for sharing...
      Holden53
      • Holden53
        • Oct 2022
        • 4
        I know this message is super old - just looking around - thanks
          • 20873
          Holden53
          just search for short killer HR-1520.Another alternative is the Mechanic TS-30A short killer https://www.badcaps.net/forum/showpo...42&postcount=6
          • Holden53
            • Oct 2022
            • 4
            Thx - will do
            • ngunay
              • Feb 2023
              • 0
              • türkiye
              hello, I am necip writing from Turkey, my field of interest is electronics, I would be happy to share what I know about repair,
              • panapat
                • Jun 2023
                • Panama
                I just saw the review of this on Youtube https://www.youtube.com/watch?v=ct1MZ1uqOYY
                • salmanbiet
                  • Aug 2023
                  • 7
                  • India
                  Yes,
                  it's the name of short killer and high ampere one...
                  ​​​​​it's a good tool but I'm not using more I try to find out manually
                  some times very helpful with this
                  thank you sir,
                  best regards,
                  Tech Salman
                    by sam_sam_sam
                    03-31-2024, 02:12 PM
                  • JimBanville
                    Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                    by JimBanville
                    The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                    Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                    I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                    I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                    09-13-2023, 07:21 AM
                  • CMCM
                    Russound CA4 Power Supply Repair
                    by CMCM
                    Hello Everybody,
                    Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                    Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                    The outputs marked 12v and 20v are all measuring only 1v.
                    The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                    The capacitors physically look clean (no bludgesor leaks) and...
                    07-03-2025, 01:12 PM
                  • Gust zhang
                    Mid 2014 A1398 MacBookPro,Is it feasible to remove the battery from the MBP and connect it to an external power supply?
                    by Gust zhang
                    ​I have a 15 - inch Retina MacBook Pro from the mid - 2014 model. Here is the link: https://www.badcaps.net/forum/showth...light=820-3662 . The battery broke some time ago. After I removed the battery and plugged in the original power adapter, the MBP could boot up normally. However, when I checked with IntelPowerGadget, I found that the CPU speed was limited to 0.8 GHz, and it ran very slowly. Later, I found a solution on GitHub. There is an open - source project called cputune that can set the CPU running speed. So I can now run the MBP at full speed. But another problem...
                    02-16-2025, 08:39 AM
