External HDD with world's largest cache
  • japlytic
    • Oct 2005
    • 2086
    http://www.myce.com/news/buffalo-cla...m-cache-66156/
  • jhead22
    Super socket 7 Cache unstable? MSI MS5169
    by jhead22
    A while ago I was able to save a super socket 7 board from the landfill. It is a MSI MS5169 ver 2.1 with an Alladin V chipset. There is 512KB L2 cache onboard and the board has Chhsi caps. I tested the board with different AMD K6-2 processors and different PC133 memory modules. The board is equipped with the latest BIOS version.
    The board is completely stable on 66FBS with the cache enabled. At 100fsb the board is only stable with the cache memory disabled. No memory errors. With the cache enabled at 100fsb I get errors in Memtest 86+ 4.xx and 5.xx
    I therefore replaced...
    10-12-2023, 08:39 AM
  • ArchangelGabriel
    Aorus 17G YD laptop, broken display, could not switch to external monitor
    by ArchangelGabriel
    Hello guys! I need a little help, I have one laptop for repair, it is an Aorus 17G YD, gaming laptop. Broken display, some cable ripped form daughter board connector, case broken, battery discharged and probably locked, etc. After I did the most tedious job I ever did on soldering back the broken cables (shielded cable) , I measured resistance on CPU and GPU core, 3 and 5 v ps and any coils I find on the board, everything seems to be fine. After I plugged the charger I don't get the power led light on from the charger connection maybe because the battery is locked , but on power button I have
    11-23-2023, 03:55 AM
  • hinisa
    Xiaomi router freezes at boot after re-capping
    by hinisa
    I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
    When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
    After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
    Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
    07-08-2023, 05:58 AM
  • eurowill
    a2141 820-01700 internal display not working / external works
    by eurowill
    Hey ya'll this is my first post on here. I recently aquired a used/broken 2019 mbp 16 a2141 with the 820-01700 board. Seller told me that the laptop needed a new lcd. However upon doing some troubleshooting i found out the lcd is fine.
    Laptop boots like a normal, plays chime, touchbar lights up however there is no image on the internal lcd. If i connect and external monitor while its already on, nothing happens and no image is displayed on external. However if i restart or boot the machine while its plugged in, the external then works and a backlight is now visible on the laptop....
    07-23-2024, 10:06 AM
  • survivalbloke
    HP ENVY HP 13-aq1013dx - screen flickering black if using touchpad or external mouse
    by survivalbloke
    SN: 8CG0213H8W
    ProdID 3C311UA
    This device came in due to the screen flickering if you use the touchpad or external mouse. It will flicker black when this occurs. If you use the touchscreen, the behavior does not appear. Also, if connected to external monitor, the external monitor is not affected by the flickering. I did a good amount of research on this, and concluded that it is due to the display driver. HP does not offer Windows 11 drivers for this model so I got the replacement drivers direct from Intel. I installed them and the problem...
    05-08-2025, 12:21 PM
