Vizio M470NV Tuning issue
    When I run the auto-tune, the channel list shows a few channels with no information. Scanning through the channles works fine until selecting one of these channels. Then none of the channels will display until power is cycled. I am thinking a tuner issue which appears to be on the main board.
    Re: Vizio M470NV Tuning issue
    if you are tuning over the air channels, do you have another antenna to try it with?
      Just the one. It is new, has both the extendable ears and a loop.
        does seem strange, did you try a firmware update?
          Not yet. I just picked up the TV second hand. I will try to get an update to the firmware. As you said, just odd that selecting a few particular channels would result in all the channels unaccessable.
          Basically, I can be on a working channel, select the next channel which seem to try to sync, then nothing. When I switch back to the good channel, I eventually get a message "Channel Not Available". Power cycle and that channel will come back up.
            try unplug tv for a few minutes, press and hold power button on tv for 30 seconds, plug back in and retry, can also try a factory reset. Might be in menu-system-reset or some such.
              Yep, tried all that. Also disconnected the antenna, scanned, then reconnected and scanned again. When I tune to one of the faulty channels, the show comes up, then freezes on the scene. Then when switching to the next channel, all channels are blank. Has to be the tuner/main board.
              Not sure it is worth the cost, but only paid $75 for the set, has a greaat picture and I tend to like to fix things rather than throw them out.
