Samsung UE40KU6172U blanking problem!!??
  • peste
    • Dec 2016
    • 13774
    • ROMANIA
    hello...Samsung UE40KU6172U, source module BN44-00806A...initial defect...the LEDs are blue (you can see the image in blue)...or bought new LED strips (same code strips) and installed...after turning on without mounting the display, speakers, etc., the Samsung starts from standby, the LEDs light up, then it stops, goes into standby and starts again...and so on...from this moment it cannot be turned off from the remote control...I put the bars back on the blue and it still does the same thing..any idea???...maybe I did something wrong!!!...maybe someone has a diagram???
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Samsung UE40KU6172U blanking problem!!??
    if you disconnect just the mainboard do the backlights stay on?
    • peste
      • Dec 2016
      • 13774
      • ROMANIA
      yes..
        • 12330
        • U.S.
        which backlight are the ones that stay on old or new, if its the new ones are they also blue?
        • peste
          • Dec 2016
          • 13774
          • ROMANIA
          I tried with the old ones (blue).....I removed the power plug of the motherboard and the bars stay on..the new ones have a white light but they were not tested with the plug removed..
            • 12330
            • U.S.
            ok, the old ones work but are blue which means they are bad unless you have a yellow diffuser sheet, seems like the new ones may be bad, make sure you bought the right ones, they may just be faulty from the factory, can you test them?
            • peste
              • Dec 2016
              • 13774
              • ROMANIA
              ok, I changed them and the new ones also work..with the power plug removed, the new ones light up white..
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4539
                • Italy - Milan
                it is possile that it wants the panel to be connected.. or it wants that the tcon be disconnected from main board and not connected with no panel
                • peste
                  • Dec 2016
                  • 13774
                  • ROMANIA
                  so, should I understand that it might not start if I don't connect the display??
                  yes ..but it hasn't happened to me with any LCD so far...but I'll try this too...
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    Originally posted by peste
                    yes..
                    usally when i get this fault it turns out too be a bad mainboard.
                      • 12330
                      • U.S.
                      with the mainboard hooked up, do you get the red light from optical port?
                      • peste
                        • Dec 2016
                        • 13774
                        • ROMANIA
                        yes... during the period when the LEDs are lit, it is also red...
                          • 12330
                          • U.S.
                          did you try it with one ribbon cable at a time hooked up from tcon to panel driver board, see if theres anything on display or any change, don't let the end of the loose cable touch anything such as metal chassis, don't want to short anything out. Best to do all connect and disconnect of cables with tv unplugged from power to avoid any errant surges and such.
                            • 12330
                            • U.S.
                            I think Vinceroger69 is right, mainboard issue.
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4539
                              • Italy - Milan
                              i remember in some newer Samsung, with a problem in the panel it can go in protection
                              • lotas
                                • Jan 2016
                                • 4859
                                • Russia
                                For this KU series - if the panel is not connected or the panel is not working, it will reboot, try turning off only the backlight and check if it will reboot.
                                • peste
                                  • Dec 2016
                                  • 13774
                                  • ROMANIA
                                  yes...dear colleagues, the problem is solved...the display has been mounted and everything works perfectly...so, be careful with these newer Samsung models so you don't run after the defect like me...thanks for the ideas and let's hear the best
                                    • 12330
                                    • U.S.
                                    ok, so the only problem was you didn't have everything hooked back up after the backlight replacement before you tested it, once all hooked up tv works as it should?
                                    • KYBOSH
                                      • Oct 2011
                                      • 581
                                      • Unknown
                                      Happy to hear your TV is working.
                                      I in the same boat as @nomoresonys ... what exactly was the problem and solution?
                                      • peste
                                        • Dec 2016
                                        • 13774
                                        • ROMANIA
                                        yes, the display had to be connected as well, otherwise the background light turns on and off, and so on.. I think it has a protection for working with a defective display.. so... without a connected display, the background light does not stay on..
                                        • Kingfreddie
                                          LED problem on samsung UE55F6475, 2 strips work. The rest is flashing every second.
                                          by Kingfreddie
                                          Ok.. this is the story:
                                          Have an old Samsung LED 3D TV (UE55F6475). First it started to lose light on the lower 40% of the screen now and then. Like for 10-60 mins and then it would work again. Then a bit later it just got stuck in that position. The lower 40% of the screen is dark, and it gets progressively darker the lower u go so it's obviously that LED strips where not working. I also looked for similar errors online and saw an exact copy and on that one it was faulty LED strips.
                                          This is kinda how it looked, just that mine were at the bottom of the screen:
                                          09-11-2021, 01:57 AM
                                          09-07-2024, 05:50 AM
                                        • howardc64
                                          Samsung UN55JU650DF network/streaming problem
                                          by howardc64
                                          Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                                          This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                                          07-09-2025, 12:44 PM
                                        • alro7779
                                          Samsung UN55MU6103F video problem; has colored stripes on the display
                                          by alro7779
                                          Hello, everyone!
                                          A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                                          09-27-2025, 11:29 PM
                                          09-06-2024, 11:40 PM
