Sony 49XD7005 synchronization problem
  • Raulnn
    • Nov 2022
    • 103
    • España
    good evening! This tv had a panel synchronization problem that I improved by canceling some outputs from the left lvds of the tcon. but a faint horizontal line still persists, and it doesn't quite look perfect. Is there any trick to know the lines to cancel? I have been reducing the number of canceled lines, but it does not improve. Let's see if anyone helps. thanks in advance.
  • Chrissygizmo
    Sony KD-55XG9505 lines on screen problem
    by Chrissygizmo
    Hello again everyone,
    This is my latest mission, to try getting this Sony tv back to normal working order…
    I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
    02-19-2025, 11:31 AM
  • crackedprint
    Sony HCD-HX80R Amplifier Volume Control Problem
    by crackedprint
    I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
    I have tried a Cold Reset as per the service manual.
    I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
    I have looked all the way through the service manual and tried many online...
    01-21-2025, 12:18 PM
  • retrorepair
    SONY KDL-40P3600 Picture Problem
    by retrorepair
    Hello gurus, hope you can assist me...
    I have a Sony KDL.40P3600, with an issue on the left side of the screen (pictures attached).
    I think the problem is the panel, but before send it to trash, i would like to get a second opinion.
    Thanks in advance.
    10-11-2024, 05:12 PM
  • guruji
    Sony mbx-266 problem
    by guruji
    Hello
    I this Sony mbx-266 it powers
    on all the voltages are normal the strange part iOS the caps key num key works which shows the machine has booted but no video at all internal dp and the ext vga or hdmi.I have changed the bios but same issue. What do I check ??
    07-25-2025, 08:10 AM
  • YasaCh
    sony kd-49xf9005 4 red blinking problem
    by YasaCh
    Sony KD-49XF9005 it power up to android boot screen and turns off immediately with continuously 4 red blinks ...
    05-05-2025, 08:40 AM
