Schematic for LG 55UF6450 TV
    Does anyone have a schemtaic for the motherboard in this TV? Thank you
    Re: Schematic for LG 55UF6450 TV
    https://www.ebay.com/itm/11372139964...mis&media=COPY
      That says it is repair service for snowy picture. I don't have that issue. My issue is that the inputs don't work. I can stream my phone through tv and it works fine, but if I plug any hdmi inputs in nothing happens.
        You are not going to repair a TV main board yourself even with a schematic. Main boards are multi layer with small and fine pitched components like computer motherboards. I am assuming you don't have specialized equipment or skills to do component level repair but asking for a schematic is a sign that you don't. You can ask the seller if he repairs your problem or buy a new main board. These boards usually have bga issues which require reballing. You can try heating the processor with a hair dryer before plugging in.
          maybe we can muddle thru, what are your symptoms?
            When I plug HDMI stuff in the tv doesn't recognize that anything has been plugged in. I do have access to high end equipment. My friend works at an electronic manufacturer as an electronics repair tech. He asked me if I had one so I thought maybe someone here might have the schematic. I've tried many times to buy a new board. They are always either sold out or charge insane amount upwards of 250$. Seems like they are actually worth about 90 to 100$. The only repair service I could find on ebay was for a snowy pictures. Thank you for the replies
              something simple to try just in case, unhook all hdmi cables, turn off tv, unplug tv from power, press and hold power button for 30 seconds, plug hdmi cable back in, plug tv power back in and try it, if no joy maybe a factory reset will work if you haven't yet tried it, I assume you already tried a different hdmi cable.
                That repair listing also lists black screen with sound and backlight.
                I would suspect its a problem with the solder balls under the processor in the middle of the PCB. Ask your repair tech friend if he does BGA rework, if not, consider the repair service if neil6 has used them before.
                  Post a pic of the main board. If you're lucky it has a separate HDMI chip which may have failed and can be replaced.
