Powersupply proble, SAMSUNG LA32R71B
  • Jesusspain
    • May 2015
    • 37
    • spain
    #61
    Re: Powersupply proble, SAMSUNG LA32R71B
    then I realized that there is a pin (a pin of the 5,4V) ... called stby and another called pon. Then I measured the voltage in st / by = 6V !!!!!
    • Jesusspain
      • May 2015
      • 37
      • spain
      #62
      no I could not believe it !!! I was there waiting for me !!! and until then I had not seen !!!
      Following this ...... ... I also realized that (some of it I know what you said budm!) .... of course! the source does not output the 12, 13, 5 and 24 volts .... until someone press the power button ...... was when he gave me to make a bridge between st / by pins ( q already had 6V) and pin Pon !!
      • Jesusspain
        • May 2015
        • 37
        • spain
        #63
        momentary bridge course! then one flasheante light (which had just replaced with a new one ..) saw appear ..... that is a good blue spark ... and continues .... in f9222l pin q wanted to jump 20 to 23 or 19 ... that I do not remember right now ... because I'm not with the tv right now ....)
          So what DCV do you have on the connectors now since now you know you have to turn on the TV so the main board will send the PS-ON signal to turn on the the rest of the power supply.
          • Jesusspain
            • May 2015
            • 37
            • spain
            #65
            already I am thinking the worst! but several times I made the bridge out that little spark that wanted to escape out of the space reserved on the plate for f9222l. then I saw that it was me grasilla plate ..... ... among some contacts that I use for welding or desoldering .... I mean a special stripper for this work. I decided to wipe it well .... and once I came clean to try to bridge
            • Jesusspain
              • May 2015
              • 37
              • spain
              #66
              budm expected that I still have to tell you it does not stop here !! jojojojojo
              • Jesusspain
                • May 2015
                • 37
                • spain
                #67
                well ... once clean .... I try again with the bridge .... and since no trace of the spark !!! and I think ..... phew !!!! I already screwed up! hahaha. I measurement as well as before the voltage plate ..... always remained as to the primary of TM801S ....... and .... yes !!! there is still voltage !!!
                  OK, I look at the diagram.
                  The ST/BY (S/B pin 2 of CNM801) is the standby voltage from the standby powers supply, the output is 6.0V rated @0.30A. This 6V is used for running the main board.
                  When power switch is activated, the main board will send the command ON to pin 1 of CNM801 (PSON same as PS-ON) to turn on the PFC Voltage Booster, the 5.4V power supply, 13V power supply, and the 24V power supply.
                  • Jesusspain
                    • May 2015
                    • 37
                    • spain
                    #69
                    Then I set and connect the plate on tv ..... and on for the first time !!! I was amazed ..... yet ...... pissed if it would also .... for making the bridge ..... etc. a fact that may be important and forget me !!! well before mounting the plate .... I was checking the voltage on the pin was larger electrolytic capacitor there ... I do not remember right now ... if you call Cm801 ... uo otherwise. Well I disconnected the 220V ..... and would check between pins ... and pass it discharged by bridging their legs ..... before measuring ohms per plate ...
                      Sorry, but I cannot understand what you are saying.
                      • Jesusspain
                        • May 2015
                        • 37
                        • spain
                        #71
                        Well after all this ..... and with the TV on ... (and the cable connected pc in ... and see the PC screen on TV ...) ....... . for a few minutes ..... 2 ... or. 3 ......... THE TV IS OFF !!!!
                          Did the PC go into standby and stop sending Video signals to the TV? If TV does not detect Video signals, it will go into standby mode.
                          Do you have other Video sources to use for feeding the TV?
                          • Jesusspain
                            • May 2015
                            • 37
                            • spain
                            #73
                            I'll watch the red LED flashes again .... and then disconnect the cable ....... 220V ...... wait a few seconds I plug it back ...... and TV TURN ...... a short time ..... is lit and goes out again and so it alone ....... ..... the red LED blinks ...... spend 1 to 2 minutes or less ...... and ignited before going on ....... ........ hear a little noise and smooth .... .... by any of ..... components and try to hear where it came from exactly the noise but I can not ..... then .... I touch with fingers .... llemas above the sinks ... .. etc .... but boto nothing unusual moment .... hot ..... nothing .... nothing ....
                            • Jesusspain
                              • May 2015
                              • 37
                              • spain
                              #74
                              budm not forgive what has not been said before ..... to see the PC image on TV Connect the cable ...... .... but until we find and tap the Source button ... .... it was not seen on the screen of the pc tv ...... ....
                              • Jesusspain
                                • May 2015
                                • 37
                                • spain
                                #75
                                this is what happened to me today with the TV and I wanted to tell you budm! Thanks for supporting me !!! I will continue tomorrow with the tv. Here now are the 0: 22horas Friday May 15 !!!! good morning I read your comments and input ..... ...... ....... and continue with it I have to say also that while ...... tv went off alone .... ... and he wanted to light ....... ever did on and off in a few seconds .... and I used to measure volts on pin 24 = sometimes 3 .... ...... and 4V He is going up .... until ..... reached 21V ..... heard that little noise while going up .... and reach 21 sl tv was going on. while half off ..... pin pin stby = 6 .... 5.4. .... 12 ..... 13 ........ I remember well that all measuring less than 24 ........... But this I have to check it well tomorrow
                                • Jesusspain
                                  • May 2015
                                  • 37
                                  • spain
                                  #76
                                  Well budm! Sorry for my bad english.....today for I go more quick...I use google traductor! Jajajajaja this is more for me write today!!! Google is not very good when I write a lot!!
                                  Thanks for listening to me!
                                  See you tomorrow!
                                  if you think of something tomorrow escribemelo and read and then tell you. thanks !! see you tomorrow !!!
                                  • Jesusspain
                                    • May 2015
                                    • 37
                                    • spain
                                    #77
                                    Write me=escribemelo... ...and. Then I read
                                    Sorry
                                    See you! Bye!
                                      09-07-2024, 05:50 AM
                                      09-06-2024, 11:40 PM
                                      09-06-2024, 08:40 PM
                                      Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                                      This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      09-06-2024, 06:20 PM
