Sony Bravia XBR-65X850B Clicking On and Off
  • powerblackout
    • Feb 2018
    • 109
    XBR-65X850B tv clicks on and off constantly after power is applied, the status LED turns on white like normal, getting brighter, but then the power supply clicks and the status LED goes off.
    POWER_ON 3.3V constant
    T-CON_ON 0V until the "off" click where it blips up to 3V then back to 0V
    REG12V is 12.6V until the "off" click, drops to 0V
    T-CON_VCC12V is 0V until the "off" click, where it looks like the voltage goes up, my meter tries to get a reading but it goes back to 0V too soon.
    I unplugged the two ribbons connecting the main board to the TCON board which let the tv turn on. i get sound using the menu button and the backlight turns on, but i do not get the test pattern on the display, it's all black.
    T-CON_VCC12V and T-CON_ON are both 0V while those ribbons are disconnected, I would assume they would need some voltage to display the test pattern on the display though?
    I replaced the main board, and the TCON board, same problem.
    Does this sound like a TCON, power supply, or display problem?
    • 12274
    • U.S.
    Re: Sony Bravia XBR-65X850B Clicking On and Off
    quick test, try it with one tcon to panel ribbon cable connected then turn on tv, then try the other cable so one connected at a time, see if there's anything on screen, need to be careful that the end of the dis-connected cable does not touch anything like the metal chassis of tv during test, don't want to short anything out, best policy is to do all connecting and disconnecting with tv unplugged from power to avoid any errant surges and such.
    • powerblackout
      • Feb 2018
      • 109
      The TCON board has 4 ribbon cables that go to the panel, 2 up and 2 down.
      When I only plug one ribbon in with everything else stock the TV comes on and the back light comes on. Here it what it looks like with only the top left ribbon connected.
      I started adding in more ribbons one at a time, after I get to 3 ribbons connected it starts restarting and clicking like originally.
      • powerblackout
        • Feb 2018
        • 109
        Here is the top right and bottom left connected. I can hear a rapid clicking sound coming from the TCON board, possibly from one of the ICs.
        • powerblackout
          • Feb 2018
          • 109
          When I have any number of ribbons connected it will also randomly click off then back on again, sometimes a few seconds apart sometimes a minute or so.
          There is a high pitch whine coming from the TCON board I picked up on video https://www.youtube.com/watch?v=PKkUfh0ThV4
          I went ahead and did this same process for the replacement TCON board. when I only connect a single ribbon the status LED flashes yellow/green meaning it wants a firmware update, but Sony's website doesn't have it anymore..
          • powerblackout
            • Feb 2018
            • 109
            I found the update process for this tv on another forum: https://www.avsforum.com/threads/off...#post-33225713
            after following those steps and getting the replacement TCON board firmware updated, the same problem happens with both now, clicking on and off no display.
            • powerblackout
              • Feb 2018
              • 109
              Along the bottom and the top of the panel are little tcon ribbon "jumpers". I removed the bottom left one and the TV started turning on with an actual image. Does this look like something that can be repaired?
              • diif
                • Feb 2014
                • 6978
                • England
                It sounds like you've ripped of one of the flex cables. A photo will confyorm this.
                  • 12274
                  • U.S.
                  can we see a picture of the "tcon ribbon "jumpers"?
                  • powerblackout
                    • Feb 2018
                    • 109
                    I have been very careful with all of the TCON ribbons, here are some pictures.
                    When the bottom left jumper is connected the board has the original symptoms. this was happening before i even opened the tv.
                    I pulled all of the ribbons out and wiped them down with IPA and a q tip incase there was any dirt on them.
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      The cable connects to a PCB, remove the metal shield that's covering it. There are components on the PCB, with luck you will find one shorted.
                      • PopsCaps
                        Sony Bravia KDL-40V2500 that will not power on
                        by PopsCaps
                        I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
                        I do not hear any sound and I cannot see any backlight.
                        I have tried disconnecting every cable on each board one at a time to see if anything changes.
                        The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
                        My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
                        03-25-2025, 11:23 AM
                      • justin35
                        Sony bravia kdl-43w755c - boot loop
                        by justin35
                        i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
                        from what i read online it looks to be an emmc issue…
                        i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
                        i took out the board and say an samsung 16gb emmc
                        i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
                        i could try to put one instead of the 16gb one, but will it work?
                        where do i get the software from?
                        any help will be much appreciated!...
                        03-06-2024, 12:26 PM
                        Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic
                        Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic...
                        10-16-2024, 05:15 AM
                      • Spc.
                        Sony Bravia KD43XF7596BAEP - Android no picture
                        by Spc.
                        Greetings everyone.
                        I also have Sony Bravia, model:
                        Sony Bravia KD43XF7596BAEP - Android.
                        What happend is that image dissapeared while we were watching tv.
                        Diagnostics:
                        1. TV turns on, no errors
                        2. Backlight turs on, no errors
                        3. Power indicator turns on, white color, no errors
                        4. Menu works on android, you can hear sound while switching channels
                        5. Volume up and down works via TV remote and via buttons
                        6. Tunner works, HEVC / MPEG-4 decoder works
                        7. I get audio from channels
                        8. No picture is present,...
                        05-19-2022, 04:28 AM
                      • Akuanka
                        Sony SLV-E780 Power Supply Issue – Clicking Sound, Need Help Identifying Faulty Component
                        by Akuanka
                        I'm troubleshooting a power supply issue with a Sony SLV-E780 VCR. The device clicks repeatedly but doesn't power up completely. I've already replaced five capacitors, but the problem persists.
                        Here's a video link https://photos.app.goo.gl/3Xki6yvCLn67gLX78​ showcasing the sound. Based on your experience, could this be due to a transformer, diode, or another component? Any guidance on what to test or replace next would be greatly appreciated.
                        Thanks in advance for your help!
                        11-23-2024, 01:12 PM
