LG 55LW5700 TV picture
  • kyho
    • Aug 2020
    • 11
    Does anyone have this problem on picture. I have LG TV 55LW5700, recently the picture has tiny vertical line, the line can be seen on the face but not easy see on dark area. I had reset the picture setting and also unplug the TV for awhile. The line may go away but it comes back again. Please let me know what is wrong.
    Many thanks.
  • nomoresonys
    • 12206
    • U.S.
    Re: LG TV picture
    can try the tape method for the line, might work: https://www.youtube.com/watch?v=N6nVJja2WxA
    • nomoresonys
      • 12206
      • U.S.
      Re: LG TV picture
      the line could be due to a bad component on the panel driver board, check the little ceramic caps for shorts, also check the resistors close to the line, make sure they are ok in tolerance and have good solder joints.
      • alfatv
        • Sep 2020
        • 353
        Re: LG TV picture
        Either panel defect or bad COF contact, no pictures help for sure.
        • mrsith
          Samsung UE58TU7100K - no picture, vertical line
          by mrsith
          Hi.
          Got UE58TU7100K with no picture - backlight comes on though. Figured out that's a perfect candidate for cut tape method.
          This model has just one LVDS tape coming off main board - and two panel boards underneath the LCD screen are connected to each other via small tape. Like curved screens. I've tried to disconnect half of the screen (5he side without LVDS connector on it, obviously), no joy.
          Disconnected the tape (main board side). Applied a small piece of tape, covering first ~4-5 pins. Powered the TV on - got picture. In negative, but that's...
          02-07-2023, 11:18 AM
        • Tr0ll
          by Tr0ll
          Original T-con:
          First replacement T-con:
          10-07-2023, 07:48 PM
        • JJAAMM
          by JJAAMM
          Problem
          07-06-2023, 06:01 AM
        • TR103
          by TR103
          - it keeps rebooting
          01-22-2025, 04:12 PM
        • chth96
          Is it possible bridging tiny broken trace
          by chth96
          When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
          cutting tiny trace.
          This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
          Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
          But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
          12-03-2022, 11:32 PM
