Insignia 32" LCD TV Model# NS-32LCD
  • Paul678
    • Nov 2011
    • 402
    #81
    Re: Insignia 32" LCD TV Model# NS-32LCD
    Originally posted by tom66
    That kind of makes sense, I don't suppose you saw a picture during the flickering? The lack of PWM control probably confuses the inverter, but it's at least attempting to light the tubes. Looks like main board at fault then.
    No picture. I was looking for a "no signal", or menu, as
    I was pressing the menu button, but nothing. Just a dim
    flashing.
    Are you certain the faint ticking from the power supply is
    normal? It's faint, but audible, and I've never heard a
    SMPS make this kind of noise. It's the first thing I noticed
    when I turned it on. I checked the back of the ps, and
    it looks normal. No bulging caps or nothing.
    If it's the main, they are going for about $50 on Ebay.....I'll
    have to think about this one, because I sold the last
    NS-32LCD I fixed for only $180.
      I'm sure you can fix it, rather than just doing a board swap. The ticking is probably because the inverter draws a lot of power to get the tubes to light, but then the power consumption drops. When it doesn't seem PWM from the main board, it probably shuts down. Not certain though.
      Post a pic of the main board - you can check the voltage regulators, fuses, switchers etc.
        If the 24vdc power supply is good, then it should be able to make inverter run without fluctuation, I would monitor the 24vdc to see if it is going up and down since the 24v power supply is rated to run the inverter board. The 24v power suppply is more likely to be rated at 4~5A.
          You could always try some car headlamp bulbs, as budm has suggested before.
          • Paul678
            • Nov 2011
            • 402
            #85
            Regarding your suggestion of car lamps: just put them on the +24V
            line, and see if the brightness is steady?
              You put the two 12v car lamps in series so they will handle 24vdc voltage.
              • Paul678
                • Nov 2011
                • 402
                #87
                Ok, I've got a bad power supply, as I suspected. It's
                just not normal to hear that kind of "ticking" sound, even
                if it's rather faint.
                I hooked my ancient Tektronix 564 to the 24V line, and
                with OR WITHOUT the 24V connectors hooked up, there is
                an awful 4-5 volt spike in the voltage, which is in synch
                with the ticking sound:
                Just a reminder of the limitations
                of a DMM, as it showed a steady 24V when measured on
                that.
                Even the 5V standby line gets screwed up as soon as the
                power supply is enabled. 5V standby by itself is nice and
                steady.
                Ok, here is the supply (sorry it's not lit very well):
                And the cheapest I found it ($35 free shipping) was here:
                http://www.rivervalleyelectronics.ne...-32fb26-20.htm
                I wouldn't mind spending some time trying to
                troubleshoot at component level, but as usual,
                I couldn't find a schematic.
                The board reads 782.32FB26-2000
                  That is one reason I use lamps for testing the power supply output since your eyes can easily see the lights fluctuation, but my Fluke 87 also has the bar graph display that response pretty fast to the voltage changes.
                    There are two small caps on the primary side of the power supply. These tiny caps almost always fail without bulging, and they're dirt cheap. They are a common cause of this problem with pulses on the output. You can use a generic (e.g. RadioShack ) capacitor to replace them in most cases, but it would be advisable to later replace them with high reliability general purpose capacitors.
                      Yes Tom, I suspect that small elctrolyics cap on the left of that large cap toward the bottom of the picture.
                      • Paul678
                        • Nov 2011
                        • 402
                        #91
                        Are you guys talking about the 2 small electrolytics, within the
                        dotted lines, in the picture I posted? One of which is to the left
                        of the huge electrolytic near the center?
                        In what way do they fail? I took them both out, and the
                        appear to test ok, about 8uF each, and no shorts. But
                        I don't have an ESR meter.....
                          Please see the PDF.
                          This power supply has PFC Voltage booster circuits, the voltage on that big cap should be about as shown when the TV is on, and lower when TV is OFF, see if the DC voltage is fluctuating, becareful if you are going to use the scope on the hot side, the TV must be plugged into isolation transformer otherwise you will damage the TV power supply. 8uF that is odd value.
                          • Paul678
                            • Nov 2011
                            • 402
                            #93
                            Please see the PDF.
                            344V on the big cap when TV is on.
                            When turned off, the big cap appears to discharge.
                            I replaced the small cap you suspected (10uF, 25V),
                            with a 10uF, 50V i stole from another board. Same problem.
                              the 344vdc is steady, not going up and down in sync with the symptom?
                              • Paul678
                                • Nov 2011
                                • 402
                                #95
                                It appears to have the symptom on it.
                                  So it can be that the PFC is having the problem (not able to supply enough power for the 24vdc power supply) or the 24vdc power supply is having the problem (drawing too much power). I have to think about it to see how to isolate the cause of the problem.
                                  It can be that large DC filter cap is bad.
                                    Usually when the primary cap fails, it takes out the PFC. Because the boost voltage has no where to go it shorts the diode. Sometimes the PFC FET survives, sometimes it doesn't.
                                    • Paul678
                                      • Nov 2011
                                      • 402
                                      #98
                                      I replaced the large filter cap with an approximate
                                      equivalent, and still the same problem.
                                      Without a proper schematic, debugging this thing won't
                                      be easy, if the problem is not something obvious.
                                      Even WITH the schematic, debugging can be tough,
                                      but without it, it's like walking through a pitch black
                                      forest.
                                      Too bad all this stuff is proprietary......
                                        Agree!
                                          Did you replace the other small cap?
                                            HP ZBook 14 G2 Base Model Notebook 14 Specification for Upgrade or Repair
                                            This specification for the HP ZBook 14 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 G2 Base Model boardview and 14 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                            09-06-2024, 05:27 AM
                                            HP ProBook 640 G1 Base Model Notebook 600 Specification for Upgrade or Repair
                                            This specification for the HP ProBook 640 G1 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G1 Base Model boardview and 640 G1 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            HP EliteBook 840 G2 Base Model Notebook 800 Specification for Upgrade or Repair
                                            This specification for the HP EliteBook 840 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G2 Base Model boardview and 840 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            HP ZBook 15u G2 Base Model Notebook 15 Specification for Upgrade or Repair
                                            This specification for the HP ZBook 15u G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15u G2 Base Model boardview and 15u G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            Lithonia Lighting versus Light of America Compact Fluorescent product quality
                                            by sam_sam_sam
                                            I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
                                            I also have back when Light of America had these light bulbs available for yard lights
                                            The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
                                            While the Lithonia lighting fixture has all most certain bulb failure
                                            So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
                                            I have only had this light fixture for not more than a year if it...
                                            07-02-2023, 03:45 PM
