i got this tv and owner who had it told me it could be moisture it sayd the screen is 100% not broken so is this fixable never seen something like this, thank you
posible water damage on led tv
Tags: None
Re: posible water damage on led tv
just had one that displayed pretty much the same pattern, was a very small crack in the screen on one corner, couldn't see it til I took the bezel off and looked closely. -
thats something i didnt want to hear it looks like water damage i will surely have to open it and see whats hapening but i cant do it for a few weeks so im just hoping someone had similar water damage not cacked and it was able to clean itComment
Water at the bottom of the screen could point to the fact the screen panel tabs would be fried. However the diffuser sheets can possible be saved. Dont wipe them, just hang them on a clothes line and let them air dry.Comment
great thank you i could fix a burned cable with microscope and a wires if its not too much i hope pixels are not friedComment
by Ugur87I have a brand new 13.6-inch MacBook Air M4 that was only used for three days and now has water damage. A glass of water was spilled over it. I examined the motherboard and there was only water next to the display connector. I cleaned it with isopropanol and the components look clean. The MacBook obviously turns on and draws 20 volts from the power supply. The keyboard backlight comes on, but the display remains black. Where should I best start? Even when I shine a light on the display, I don't see any image. I have all the tools I need, including an infrared camera. Where should I best start?...
by edugimenoHi! My friend just brought this audio amplifier/speaker fro his music band saying they realized its got no sound. Led powers up but there no sound at all
I opened it and found 3 board. 2 of them are for input plugs and potentiometers, and the other larger board has the amplifiers for 2 large speakers that it drives
There's also a large toroid transformer that feeds a lower voltage to the first 2 boards and a larger voltaje (36x2 rectified close to 100v) to the power board. The power board has the plugs for both speakers
There is only one signal wire connecting the first boards...-
by Joel OhanaHi,
I have a Lenovo IdeaPad 3 15IAU7 that suffered water damage. It doesn't turn on (white power light flashes when on button pressed), and the amber light flashes when plugged in.
Symptoms:- Short detected – sparks appear when touching the charging port connection with board with a metal (even a multimeter probe).
- Visible damage – after cleaning corrosion, I found 4 possibly burnt memory chips near PC3165, labeled UD5, UD6, UD7, and UD8.
What are my next steps to diagnose and possibly repair it without replacing the entire board? Any guidance would be greatly... -
by s_henyaHi Mac experts :-)
Im usually not getting too many Mac logic boards repairs, (mostly PC laptops)
This Mac isn't powering on not boosting to 20v, stays at 5v with 0.0Amps.
Took out the board and it suffered some water damage, see attached pics.
All cleaned with IPA but due to long time with corrosion something already got shorted...
any advice on the below:?
1. Looking for relatively safe location for voltage injection as all of the caps around that area has 0.0ohms resistance.
I tried injecting 0.5v on one of the caps... -
by rtstormHello, i got an HP EliteBook 840 G8 that has water damage, and i found this component has damage on it U60600. What is that component? I have schematics and boardview and the par no is:
SINERGY_SYV128RAC_QFN_20P i cannot fount it anywhere. Is this component have some other name?
Here is schematics + boardview... - Loading...
