Lg50pk tv shows double image, mirrored
  • edugimeno
    • May 2017
    • 581
    • Spain
    Hi there!
    This lg50pk tv set has started showing a second mirrored imaged superposed to the original
    See attached, note how the right half is the same as the left but mirrored
    Is this a common fault?
    Thanks!
  • edugimeno
    • May 2017
    • 581
    • Spain
    Re: Lg50pk tv shows double image, mirrored
    No one? Im guessing something with the T-con board?
    • diif
      • Feb 2014
      • 6978
      • England
      You can do the LG self test to rule out the mainboard, it's possible it's a BGA issue.
      You could also apply heat to the processor and see if it clears up the image.
      • edugimeno
        • May 2017
        • 581
        • Spain
        Ok so you believe this is related to MAIN board more than T-CON?
        Also I've found some videos of people with duplicated (but not mirrored) screen on left and right halves and they fix it somehow in the menu on screen (not sure if a hidden service menu as it was a foreign language)
        Thanks!
        • diif
          • Feb 2014
          • 6978
          • England
          If the issue persists the problem is with the logic board or buffers, if it's gone then it's the mainboard.
          • edugimeno
            • May 2017
            • 581
            • Spain
            Ok how do I perform the self test? Is this in the menu?
            • diif
              • Feb 2014
              • 6978
              • England
              With the power off, disconnect the cable between the logic board and mainboard and on the logic board a couple of holes or pins are bridged. Power is then applied and the TV will turn on.
              • edugimeno
                • May 2017
                • 581
                • Spain
                Ok I forgot this is a plasma TV so there's no T-con but a logic board and Z-sus /Y-sus boards....
                I don't have this TV in my hands yet but I will try as soon as I get it
                • edugimeno
                  • May 2017
                  • 581
                  • Spain
                  I found this video, not same brand, and not mirrored, but it looks like some TV's have a hidden menu that allows some hacking like double image, could this be the same?
                  https://www.youtube.com/watch?v=QYnKJdddgns
                  • howardc64
                    TCL 49S405 double image
                    by howardc64
                    LCD displays a 2nd image slighty offset vertically. And multiple pairs of black lines along the bottom. Probably common as google "TCL 49S405 double image" pulls up this ifixit post ( link ) with identical ( nearly, but their fault seems to be on the other half of the panel than mine ) problem without solution.
                    This one looks to be a more difficult to diagnose because most? of TCON seems integrated ( CSOT BGA on buffer baord) into the left panel edge board ( looking from rear of TV) There are 2 buffer boards for each 1/2 of the screen. Main connects to the left buffer board...
                    06-23-2025, 03:20 PM
                  • Cornito
                    Samsung UE55RU8000 reboot and then double image after heating up
                    by Cornito
                    Hello team,
                    I'm back with another tv and another problem.
                    I try to improve my knowledge on fixing TV, and all technics used until now are not fixing correctly the problem.
                    First, reboot issue, I use tape Method to find out the right side that cases the issue.
                    Then using this it's working for quite 1hour30, then at some point of time the image became double on the bottom for half the screen.
                    Then double image reduce in height and move to the top.
                    The image is like folded on around 1cm and the bottom has been moved to the top by 1cm.
                    When I...
                    03-31-2024, 01:37 PM
                    HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                    This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                    09-12-2024, 02:20 PM
                  • jason123
                    Hisense 65R6E3 double-image / horizontal strips - TCON?
                    by jason123
                    Hello all. 3 years back, with your help, I replaced the LEDs on this TV. It's been working great. Yesterday, I turned it on (garage TV), and it has blurred horiz / vert lines as you see in photos. Definitely no physical hit or damage. Top 1/6th of the screen is perfect. Could it be main / TCON board? No tabs to cut on this model. Thank you...
                    07-19-2025, 08:07 AM
                  • piershs
                    Toshiba plasma 50WP16 wierd double image fault
                    by piershs
                    My 2001 Toshiba 50WP16 50" plasma TV has, after 20 years of trouble-free service, developed a wierd fault in the last 14 days during normal viewing - with no loud bang or smoke or any other excitement.
                    Every 15-30 secs the right hand half of the image has a "glitch" for about 1 second before reverting to normal. The glitch has two forms and also depends on the aspect ratio setting (see photos):
                    • 16:9 either a) a visible seam between LHS and RHS of impage or b) LHS image duplicated on RHS (photos 16x9)
                    • 4x3 either a) no image on RHS or b) RHS image offset by 1/6th
                    08-01-2020, 01:07 PM
