Samsung UE48H6620SV, no picture
  • JRade
    • Nov 2013
    • 28
    • Serbia
    The backlight was not working properly, I replaced it and it works
    but when I installed the board and connected the 2 straight cables to the T-con, there is no backlight.
    I connected the satellite receiver with a scart cable and there are tons of them.
    When I disconnect one flat cable (left or right) there is a backlight, but there is no image on the display, but of course there is sound.
    When the backlight is on, the entire screen is dark blue.
    There is a voltage of 12V DC on the T-con and the fuse on the T-con is correct.
    Please help, what should I do next?
    Thank you!
  • nomoresonys
    • 12331
    • U.S.
    Re: Samsung UE48H6620SV, no picture
    check your tcon voltages, see if they're what they should be, some testing there and plenty more videos on the subject on youtube: https://www.youtube.com/watch?v=eGMJnTlPW1Q
    • nomoresonys
      • 12331
      • U.S.
      make sure you put all the cables and connections back on, its easy to miss one on reassembly.
      • JRade
        • Nov 2013
        • 28
        • Serbia
        Ok,thanks!
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4542
          • Italy - Milan
          How do you fixed backlight, entire set of strips, single strip or single leds?
          • JRade
            • Nov 2013
            • 28
            • Serbia
            single leds
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4542
              • Italy - Milan
              The backlight is still faulty, another led or more is still NG
              • JRade
                • Nov 2013
                • 28
                • Serbia
                All the lights are the same 3V model, I tested them
                all the lights are on
                  09-07-2024, 05:50 AM
                • JJAAMM
                  by JJAAMM
                  Problem
                  07-06-2023, 06:01 AM
                • shelby5041
                  Samsung LCD TV no picture backlight on no 12v at tcon
                  by shelby5041
                  hi
                  i have a samsung lcd tv
                  it powers on with sound and backlight but no picture
                  all voltages from PS are good 12v 3.3v and 5v
                  whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
                  i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
                  no 12v at the tcon fuse
                  i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
                  the odds of having 2...
                  10-08-2021, 08:21 AM
                • Dodgethis
                  Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                  by Dodgethis
                  Hello all,
                  This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                  09-11-2024, 07:39 AM
                • brithepi2k
                  Samsung UE75TU7020k No picture, Standby blinks 2 times
                  by brithepi2k
                  My Samsung UE75TU7020k lights up fine when one of the ribbon cables are disconnected from the main board, lights stay on but not getting half a picture, I do the same with the other ribbon and put the other one in and lights stay on but not getting half a picture. The standby light flashes 2 times then reboots then it then tries to come back on again and just keeps looping until I take either one of the ribbon tables out (doesn’t matter which one I take out it stays lit when either one is out). I’ve tested the backlights but all working with none shorting out, I’ve replaced the main board...
                  04-23-2025, 10:05 AM
