LG 49SK8000 intermittent dim backlight zones
  • zward
    • Oct 2022
    • 5
    I have a 2018 LG 49SK8000 with a bit of an odd problem that I haven't seen discussed elsewhere. It's an edge-lit (bottom) LED UHD TV with local-dimming (6-zones I believe). About 5-10% of the time when I turn the TV on after it hasn't been used for a couple hours, one or more backlight zones will not power on normally.
    Some observations:
    - If I power off (standby) and back on, it almost always works normally and continues to do so indefinitely.
    - If I switch inputs, the zone will briefly light up and then go dim again.
    - If I change the video preset (e.g. cinema to HDR effect), it will also briefly light up and then go dim again.
    - A zone may come on normal, dim, or totally dark.
    - Local dimming settings, including off, have no impact
    - The dim zone seems to vary each time, although maybe the ones on the sides are more commonly problematic.
    - This happened very rarely when the TV was newer, but has become somewhat more frequent.
    The backlight is usually at 100, which I've now learned is not the best thing for longevity.
    I'm ready to open it up and do some testing, but since I can't reproduce the problem reliably, I'm afraid it will be a waste of time. This seems to potentially be a power supply (includes the LED driver) vs LED strip problem, but that's just a guess. Maybe something that is impacted by a cold start and is resolved after a brief warm up?
    I have attached a few pictures of the screen displaying a white test pattern, as well as pictures of the PSU from Shop Jimmy. 3rd pic is it looking normal.
    • 12083
    • U.S.
    Re: LG 49SK8000 intermittent dim backlight zones
    make sure the firmware is up to date.
    • zward
      • Oct 2022
      • 5
      Thank you for the suggestion. Firmware is up to date using the built-in updater. I had long hoped that would do the trick, but no dice.
        • 12083
        • U.S.
        Some turn all the eco, ambient and such off to keep it from being so annoying but then you probably lose some of the benefits of the local-dimming, wonder if its maybe a resistor that isn't doing what it should anymore?
        • zward
          • Oct 2022
          • 5
          The eco mode and ambient light sensor is turned off. This phenomenon happens with local dimming off altogether. Local dimming isn't that useful on this TV because the dimming zones are so huge (6 vertical sections basically).
          My guess is a bad solder joint, which could be anywhere, or something with the driver section of the PSU.
            • 12083
            • U.S.
            Indeed, local dimming is pretty much an oxymoron on an edge lit tv.
            • Storyteller12
              • Jun 2020
              • 624
              Have you tested the backlights to make sure their not going bad? Try turning the backlights down to like 50 and see if the problem persist or if it fix the problem.
              • zward
                • Oct 2022
                • 5
                Ok I'll give that a try. My initial thought was that the backlight itself is ok since when it powers up ok, it continues to work fine indefinitely.
                I feel like it very rarely did this when it was relatively new also - should have replaced it or addressed it back then while it was under warranty. But that also makes my think it's not just a worn out backlight.
                • howardc64
                  Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                  by howardc64
                  Problem
                  Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                  Model & Board Pics
                  Conflicting Spec
                  Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                  https://www.shopjimmy.com/vizio-gj-2k1...
                  10-10-2024, 01:16 PM
                • C152Heavy
                  by C152Heavy
                  Summary for TL-DR readers:
                  • VCC pin (18) of PFC...
                  01-11-2023, 02:53 PM
                • triplefour
                  by triplefour
                  09-13-2023, 10:43 PM
                • DanPoka
                  Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                  by DanPoka
                  I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                  Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                  This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                  02-15-2025, 05:05 AM
                • siccfix
                  HP Omen 15-ek0013dx - Odd 4-Zone RGB Issue, Replacing Entire Keydeck Didn't Fix It
                  by siccfix
                  Replaced the keyboard+LED backlight+topdeck unit with a completely assembled aftermarket part a few months ago due to failing keys (Spacebar, X, R; seems to be a common issue for 2020 model). I thought this would also fix my RGB backlight issue but the problem remains, actually it got worse, so it has to be a failing part on the mobo itself. The middle RGB zone can no longer light up blue and is instead stuck on green, even if all kb backlight is turned off that zone stays lit..
                  Does anyone know what part number the IC labeled UI3 is? Seems to be some kind of LED controller chip....
                  04-24-2025, 08:54 AM
