LCD micorprocessors
  • angelos
    • Dec 2012
    • 568
    • South Africa
    LCD micorprocessors
    Hi there, i have always wondered about the processors that run the LCD TV. If i had one whose micro processor was shorted and i ordered a brand new one and managed to re solder it on the board would it work? I mean after all where does the operating system reside? Is it in the memory chip (25Q32) or is it loaded in the ROM of the micro processor? Just wondering???
    If my question is not clear I can elaborate further. I am not talking about an LG or Samsung board but rather the TSUMV59XU-Z1 chip used in these cheaper Chinese sets.
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4318
    • Italy - Milan
    Re: LCD micorprocessors
    What do you mean for lcd microprocessor? The main chip in a tcon is not a microprocessor, but have something similar to a program, it is stored inside itself when outside there isn't a flash, or outside when there is an external flash.. the i2c eeprom doesn't apply, it's only settings..
    • lotas
      • Jan 2016
      • 4580
      • Russia
      If we are talking about TSUMV59XU-Z1 (MStar), then the firmware is in spi flash 25Q32, just change the processor and that's it, if the firmware remains alive, then everything will work.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4318
        • Italy - Milan
        It it's the main processor, what about the unique codes stored in it like mac address etc..? Is a new chip virgin and have to be initialised? i know there are special factory software to do these jobs.. these softwares like the other ones to access and program system by uart are no more available around..
        • lotas
          • Jan 2016
          • 4580
          • Russia
          This is a normal, simple scaler controller, it does not have any MAC, etc. All settings, panel and remote control codes are stored in spi flash.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4318
            • Italy - Milan
            Are you advicing an universal board? For me them causes a lot of trouble with connectors /case management and an annoying visible external ir receiver.. but anyway it's a matter of flavours..
            • lotas
              • Jan 2016
              • 4580
              • Russia
              I do not advise anything, I just explained that replacing this controller on the motherboard will not create any problems.
              • angelos
                • Dec 2012
                • 568
                • South Africa
                Have you ordered some from Aliexpress and soldered it into a unit and it worked?
                • lotas
                  • Jan 2016
                  • 4580
                  • Russia
                  No, I personally did not order, but I know colleagues who changed and there were no problems.
                  But it can also fly off the firmware of his native.
                  • angelos
                    • Dec 2012
                    • 568
                    • South Africa
                    Ok, i will order and sort this out. Thank you for your advice.
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4318
                      • Italy - Milan
                      check better because there are prettiest board than the simply one posted by lotas..
                      • lotas
                        • Jan 2016
                        • 4580
                        • Russia
                        What do you mean?
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4318
                          • Italy - Milan
                          in the past i have seen on AliExpress more powerful universal boards than the one you posted.. i was writing to the op not you.. bye..
                          • lotas
                            • Jan 2016
                            • 4580
                            • Russia
                            I posted a photo of the board on which this controller is used (TSUMV59XU-Z1) and showed that there is no need to program anything on it (mac address ...).
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4318
                              • Italy - Milan
                              SORRY! I had not understood.. thanks..
                              • Taurus12
                                Optiplex 3050 micro 2 blinks followed by 3 blinks issue
                                by Taurus12
                                Does anyone have an idea of what might be the issue with my 3050 micro? I have tried replacing new cmos battery but still the same
                                I am not sure if its the powersupply that I'm using is the issue since its the original powersupply. its a laptop powersupply with the same specifications with the 3050 micro so i guess it should be fine.
                                i also tried replacing the bios but with no avail, everytime i try another bios it gives a different blinking lights
                                Any recommendation on what I have to do next? Thanks in advance
                                06-10-2025, 05:05 PM
                              • Isabella91
                                Possible to convert eMMC Socket to a micro SD Card socket?
                                by Isabella91
                                I have seen many posts where the eMMC can be read via a SD card reader, however can the opposite be achieved?
                                Read/Write a Micro SD Card from an eMMC Socket.
                                I have a Motherboard with a Kingston BGA153 ball socket, using HS400 bus mode, which is 8bit, as Micro SD is usually 1bit or 4bit mode, I accept that a loss of speed in read/write will occur, but I would sill like to convert.
                                Theoretically speaking, Im thinking if I hard solder DAT0-3 from eMMC to SD Card Reader, this should force 4-bit mode, or only DAT0 to force 1-bit mode.
                                Not to remove...
                                01-14-2024, 05:10 PM
                              • Altemon Moura
                                Optiplex 3000 micro
                                by Altemon Moura
                                Unfortunately, when removing the chip
                                (GIGADEVICE 25R256EYIG)
                                It broke in the hot air.
                                Will I be able to buy this same model?
                                (GD25R256EYIG)
                                "Can I burn the Bios?"
                                motherboard
                                DELL Optplex 3000 - 202040-1 D10NK$HA
                                Optiplex 3000 micro
                                Service tag: C7CG7T3
                                SERVICE CODE: 26565563271​
                                05-20-2025, 06:35 AM
                              • tracks
                                Dell 3080 Micro BIOS dead
                                by tracks
                                Hello all,
                                I have a Dell 3080 Micro with a problem. As it is right now, it seems to be boot looping, maybe... There's no output, just fan on and power led lights up and blinks off every 2 seconds or so.
                                Previous owner told me he bought it with a BIOS password, he tried to use a CH341A programmer with some random test clip and tried to mess with it while it was powered on. Now it won't boot.
                                I tried to dump the bios with an EZP2023+ but I can't get a consistent read. Every time the dump is different, so it's unusable. I think the BIOS chip is fried.
                                04-19-2025, 03:42 PM
                              • re-atari
                                Anycubic Photon 5.5 3D printer 25Q32 flashrom dump needed
                                by re-atari
                                Hello all, as the title says, I'm very much in need of a valid firmware dump of a Anycubic Photon 5.5 3D resin printer. It's stored in a Winbond 25Q32, so it's 4Mbyte.
                                Here's a little background for my request. A few weeks ago I bought this 3D printer from a guy who had moved on to a PLA printer. I got it at a vey reasonable price, as it was in a defective state. The seller told me that he had experienced a power failure during a firmware upgrade, after which the printer appeared to be dead. He thought the firmware was corrupted in such a way that the printer was now bricked. As he...
                                02-03-2025, 06:49 PM
