Samsung UE55NU7025K not starting/looping
  • nebula
    • Apr 2010
    • 16
    • Spain
    Hi all, I have a Samsung 55" with a startup problem, backlights light up and there is an attempt to show a picture but it turns off, flashes 3 times on power LED and tries again to start. When I remove one of the T-Con flexes I can hear the startup sound but nothing appears on the screen apart from the backlights turning on, same happens each side. I cannot see any damage to the T-con strips so I am not sure at this point if the problem is Mainboard or LCD panel.
    The customer claimed the TV just stopped showing a picture all of a sudden.
    Any help would be highly appreciated.
    Main/Power board is BN9646822A - Panel is CY-NN055HGLV6H
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4536
    • Italy - Milan
    Re: Samsung UE55NU7025K not starting/looping
    locate on the panel's distribution boards an eventual short circuit on caps/diodes
    • nebula
      • Apr 2010
      • 16
      • Spain
      Tested all caps and diodes on both boards, nothing was short or damaged. Not sure where to look now.
      • yokoono
        • Apr 2010
        • 512
        If you don't have an image on half the screen when you disconnect a ribbon, it means that the protection comes in at the t-con. To see which part of the screen has problems, you must cancel the t-con protection.
        • nebula
          • Apr 2010
          • 16
          • Spain
          This is an all-in-one board with PS, Main and Tcon on one PCB. I can't find anything relevant to this type of board online, just videos in hindi for common T-Con boards.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4536
            • Italy - Milan
            the panel's load can lighten the power on the supply rail that feeds the leds driver i guess, so a difference in current can make a faulty led to work or not..
            • nebula
              • Apr 2010
              • 16
              • Spain
              OK so you are suggesting the problem lies with the board and not the panel? I don't want to risk replacing the board only to find that isn't the issue.
              • Storyteller12
                • Jun 2020
                • 625
                Try taping some pins going from the board to the panel. See if you can get it to stay on or show a picture. If so then it’s the panel. If not possibly the board
                Have nothing to lose at this point. Honestly this model is trash and I wouldn’t put any money into it. If you can fix for free great, if not trash it
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4536
                  • Italy - Milan
                  No i mean bad leds..
                  • comptek
                    • Aug 2013
                    • 606
                    Disconnect power supply from Mai board backlights should fire up ok
                    Disconnect main board to screen bothe lvds cables see if it boots properly if it does panel is shorted, use tape to insulate lvds top five or six traces of the top lvds cable is a good start
                    • nebula
                      • Apr 2010
                      • 16
                      • Spain
                      I already stated in my first message that backlight isn't the issue... with either one of the flex going to T-Con connected it boots as I can hear the startup chime, with both connected it reboots. I'll reassemble and return to the customer as I'm not prepared to spend time or money on it just to find out the panel is bad. Thank you everyone for your input and time.
                      • DarkoOhrid
                        • Apr 2012
                        • 4
                        • Macedonia
                        I have the same problem.The problem is panel.When I disconect any flat from T-con,the tv starts and I can hear audio.When the connect both flat cable from T- con the tv restarts.
                          • 12328
                          • U.S.
                          right on both tvs, panel problem.
                          • howardc64
                            • Jun 2017
                            • 653
                            If panel distribution board has shorted rails (by testing both side of caps for continuity), then thermal cam + voltage injection can find it. Recently fixed one like this.
                            https://www.badcaps.net/forum/showpo...2&postcount=86
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4536
                              • Italy - Milan
                              usually there's no need of expensive thermal cam, it is enough an average dmm, when short is complete, but the OP said no shorts..
                              • howardc64
                                • Jun 2017
                                • 653
                                Interesting, whats the technique to find the specific shorted cap with DMM? I'm only aware of voltage injection with ISO / flux / thermal cam but am not a professional. Got the used 1x thermal cam for $60 as I see micro-soldering repair techs use it all the time on phone and laptop boards.
                                Yes, OP found no shorts in post #3, left the note for poster in #12
                                  • 12328
                                  • U.S.
                                  you are absolutely correct Howardc64, a thermal camera is a very good investment and can find shorted components very efficiently.
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4536
                                    • Italy - Milan
                                    Hi, very simple, use the DMM as the milliohm meter, only take notice of the decimal part, the integer one is obviously zero, dont use less than about 15$ dmm, the cables should be thick enough, no kids games..
                                      • 12328
                                      • U.S.
                                      sure its that simple, thats why there's like 100 videos on youtube about how to make a miliohm meter right, BECAUSE they just aren't needed, NO its not a kids game, that's why intelligent grown up people are making and usuing them.
                                        • 12328
                                        • U.S.
                                        some show how to make a fairly simple circuit to turn a cheap multimeter into a miliohm meter, needed if your meter lacks miliohm function, not a matter of moving decimals, which is hilarious btw...LOLOLOL.
                                          09-07-2024, 05:50 AM
                                        • max789
                                          Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
                                          by max789
                                          Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
                                          I made the following tests:
                                          1. Disconnected the main board from Power Board = backlight works.
                                          2. Connected the main board and disconnected the T-Con = backlights does not work.
                                          So I ordered a main board from Ebay also BN41-02156A but from...
                                          01-18-2024, 06:56 AM
                                        • K212
                                          Samsung QE65Q700TATXXC is not starting
                                          by K212
                                          my Samsung QE65Q700TATXXC has stopped working recently. It worked fine during the morning, and when trying to start it later the same day it just refused to start.
                                          The standby LED is working, but nothing happens when pushing the power button, other then the LED blinking once. No picture, no sound, no chime, no relay click. I tried a cold start, and other recommended fixes from Samsung. Nothing worked. Then i even tried to reflash the firmware, but nothing happened, not even flashing of the standby led etc.
                                          I contacted Samsung support who said it is most...
                                          07-31-2025, 12:45 PM
                                          09-06-2024, 11:40 PM
