Choosing an in circuit ESR tester
  • rb0746
    • Jan 2010
    • 42
    I am beginning to realize the the value of such a tool for trouble shooting .
    I was hoping to get some help in my selection/purchase.
    A Couple things to keep in mind are: 1) I live in Canada and 2) I am on a budget .
    Cheers
    Ron
    When I told my doctor I broke my leg in two places while carrying a big Monitor, he told me to stop going to those places.
  • bp1
    • Jul 2010
    • 46
    Re: Choosing an in circuit ESR tester
    I have just bought the esrmicro V4. Here are some links which you may find interesting on esr meters. They certainly helped me in my purchase choice.
    https://www.badcaps.net/forum/showth...257#post114257
    https://www.badcaps.net/forum/showthread.php?t=7394
    Hope the above helps
    kind Regards
    bp1
    • tmwalsh
      • Jan 2009
      • 119
      I thought that all of the ESR meters worked with the capacitor under measurement out of circuit. Am I mistaken?
      tom
      • Radio Fox
        • Jan 2010
        • 281
        tom
        The only certain way of knowing if the ESR is OK, is to measure the capacitor out of circuit.
        Depending on the circuit layout, it is sometimes possible to measure the ESR while the capacitor is still in-circuit. If you measure a high ESR of a capacitor while in-circuit, then it is bad, but if it measures OK while in-circuit, it could be good or bad.
        Many circuits, especially PSU's have electrolytic capacitors in parallel. If your ESR meter shows both of these capacitors to be OK, it could be that one of them is still bad, but the good one in parallel is masking the high ESR.
        ________________________________________________
        Invisible airwaves crackle with life
        Bright antennae bristle with the energy
        • PlainBill
          • Feb 2009
          • 7034
          I would add to Radio Fox's explanation that interpreting the readings in terms of the circuit can help eliminate some of the guesswork. For example, if four capacitors are in parallel, the ESR spec of each capacitor is .06 ohms, and you get a reading of .03 ohms, the capacitors are bad (the expected reading would be .015).
          HOWEVER, capacitors are usually specified quite conservatively. When new, the capacitors probably each read .01 or .02; the circuit would work reasonably well if the total ESR was .5. Early this year I picked up a fairly new Philips LCD TV that was exhibiting the classic 'bad caps' symptoms. Most of the time it would start after a couple of tries.
          Opening it up, I found a number of bloated caps. Checking their ESR in circuit showed they read well over 1 ohm. Removing them from the circuit, each read much higher. The new capacitors were spec'd at something like .06 ohms, all read .01 or .02. Other similar capacitors in the TV gave readings well below .05. And when the caps were replaced, the TV worked perfectly.
          PlainBill
          • Tarot Superstars
            Short Circuit tester
            by Tarot Superstars
            Hello.
            I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
            The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
            Link
            The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
            https://www.youtube.com/watch?v=0eixDdCpiO4
            My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
            09-25-2023, 09:11 AM
          • Sus256
            HISENSE 65E7KQ PRO - no boot
            by Sus256
            Hi all!
            HISENSE 65E7KQ PRO
            RSAG7.820.13512 - chassis
            MT9618BAATAB - cpu
            RSAG7.820.12059 - power
            HD650Y3U77 - panel
            KLM8G1GETF - emmc
            The TV does not turn on, the standby indicator is on. All voltages are present.
            Emms is dead. Not readable, not detected.
            Replaced emmc.
            But with another dump there is no launch
            Terminal log
            UART
            AC_ON
            RPMB key is not yet programmed
            HASH1_VERSION=0x00000000 64bit
            E-B
            FDE enabled
            layout pattern onebin by SAR7,0...
            06-01-2025, 02:11 AM
          • Astonished
            Fixing the Charge Circuit of the Batteries of the DC Motor
            by Astonished
            Hi friends of electronics
            What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
            The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
            Please help me fix this circuit.
            (the datasheet of the IC: https://pdf.datasheet.live/28...
            01-28-2025, 06:24 AM
          • rddube
            Lenovo L490 Ram voltage circuit malfunction
            by rddube
            Hello friends,
            Looking for some guidance here. The RAM voltage circuit on this motherboard keeps burning out PU301 which is a RT8231AGQW. Copy of the board with the burnt chip attached with some voltage measurements and copy of the schematics also included.
            I think I've checked almost every component in the circuit, but when I change the RT8231, the laptop starts I have 1.2V on the inductor for about 10 seconds and then the RT8231 goes south and no more voltage on the inductor. All other voltages on the laptop are good, this is the only one conking out for a reason I...
            07-15-2025, 04:41 PM
          • M1NEBLANK SHOW
            MSI B250 Gaming M3 Short circuit in CPU power supply circuit
            by M1NEBLANK SHOW
            Hello. MSI B250 Gaming M3 board, short-circuit on the power supply. Found a problematic mosfet VQ1
            (N-PK616BA_PDFN8-HF) soldered it out - short circuit is gone. I replaced VQ1 + VQ5 (N-PK632BA_PDFN8-HF). VQ1 was replaced with PK618. After starting attempt VQ1 is lit again. What can be the problem? In the driver?
            Schematic and Boardview here
            04-04-2025, 03:57 PM
