Vizio E552VLE Schematics needed! [no power on]
  • Holes Flow
    • May 2020
    • 9
    Experts,
    Like other posters, I cannot get this behemoth to turn on, nor does the Vizio "off light" illuminate. Bought anther power board-no change.
    I have no voltages on any of the connectors where voltage levels are indicated. I have voltage on one side of the isolation transformer, and nothing on the other side-on both boards.
    Its becoming obvious that the controller board needs power to send a signal back to the power board, but no juice at ALL gets to the control board. REALLY need a schematic...
    trying this way... vBulletin can be finnicky...
    https://drive.google.com/file/d/1xBJ...ew?usp=sharing
    https://drive.google.com/file/d/1wrX...ew?usp=sharing
    https://drive.google.com/file/d/1wr1...ew?usp=sharing
    https://drive.google.com/open?id=1wk...s&usp=drive_fs
    https://drive.google.com/open?id=1wi...s&usp=drive_fs
    ...hope the above links work...
    TIA!
  • Holes Flow
    • May 2020
    • 9
    Re: Vizio E552VLE Schematics needed! [no power on]
    The message you have entered is too short. Please lengthen your message to at least 1 characters."
    Where is the message I wrote?
    attaching 6 pis here as the forum said it failed to make the links to the image on GDocs...
    basics: E552VLE no power on, no light, no power at ALL from power board, so nothing to control board.
    • Holes Flow
      • May 2020
      • 9
      I've since removed the PS and controller boards, keeping the interconnections, and brought to bench.
      I could trace everything a lot easier with a schematic, but I guess I have to start drawing the circuits by hand... joy...
      • dskall
        • Oct 2016
        • 2905
        • usa
        Need to see picture of connector legend to mainboard. Probably have a bad mainboard.
        • Holes Flow
          • May 2020
          • 9
          I see the signal for on on the silk screen of the power board, that is, the signal is coming from the control board. But the controller board isn't getting any power whatsoever, there is no power on any of the pins of any of the two connectors that send power over from the power board to the controller.
          But still, I'm curious if the signal on that pin is supposed to be a short to ground or go high to a certain voltage.
          If anybody has links to any schematics even schematics in this general series which are probably going to be similar control boards, I would really love to hear from you...
          TIA!
          • R_J
            • 9525
            Do you have 5.1 volts on CN2 of the power supply board?
            What isolation transformer are you talking about? You do know that the primary side uses hot ground which is different from the secondary side ground.
            • Holes Flow
              • May 2020
              • 9
              Yay! @R_J I have 5.1V on CN2! I have the board completely removed on bench, no connectors to the main/control board.
              Without the controller board, the 5.1VDC is present continuously on pins 1, 2, 3 of CN2. However, as soon as it powers up with CN2 and CN5 connected, the 5VDC is only present for 4-5 seconds on powerup.
              Unplugging CN5 (+18V) from the power board allows the 5.1VDC to continue on power up. After a few tries w/out CN5. 5.1VDC goes away after only 1 second now... Ain't it great when symptoms change?! :-(
              Progress!
              P.S. I have been over the boards with a microscope, and have tried a different power board, and no change in symptoms. Am I taking the $130+ plunge on a controller board, or does anyone have a schematic so I can t-shoot at component level?
              • Holes Flow
                • May 2020
                • 9
                @R_J,
                "What isolation transformer are you talking about? You do know that the primary side uses hot ground which is different from the secondary side ground."
                There are 2 transformers on the power board, crossing the primary-secondary line. I cannot find them by part number in the Interwebs...
                • Holes Flow
                  • May 2020
                  • 9
                  Looks like everything on CN2 (JP2 on CTRL board) & CN5 (JP3) is shorted to ground. Everything around those two jacks is less than 1 Ohm to GND. I'm talking about no cables connecting the CTRL board to any others.
                  • captainKKK
                    • Sep 2018
                    • 287
                    Check the U801 and all the Schottky around it for short to ground
                    • Holes Flow
                      • May 2020
                      • 9
                      Thanks for the tip! Every bloody thing shows a short! And I have no IR camera, but do have a variac... Hoping it wouldn't come to that...
                      Thanks again!
                      will update.
                      • dskall
                        • Oct 2016
                        • 2905
                        • usa
                        You can always use alcohol.
                        • Holes Flow
                          • May 2020
                          • 9
                          I cannot locate this IC, and the numbering doesn't look like the rest. Here are 4 shots, with the 4 and 14 conductor cables being the power ones from the power board...
                          I think this is a link to the folder: link
                          • PantherDave
                            by PantherDave
                            Hi all!
                            05-29-2024, 02:01 PM
                          • GLISIT
                            by GLISIT
                            01-16-2025, 02:29 PM
                            by sam_sam_sam
                            03-31-2024, 02:12 PM
                          • iulik17d
                            Intel Arc A380 videocard power limit remove - BIOS needed
                            by iulik17d
                            Hello everyone!
                            The Asrock A380 low profile card (ID 8086 56A5 - 1849 6006) have an power limit of 45W. Intel removed the possibility to increase power using the software utility, anyway the card is in an proxmox machine that doesn't run windows.
                            The same hardware is in another form by the name Asrock A380 Challenger that have the same VRMs and the power limit is at 60W. I searched online and found on another website an .bin bios file from the Challenger variant, that I flashed using an CH341a. Flashng worked well, I put the card in PC and booted. GPUz shows that new device ID is 8086...
                            01-10-2025, 02:33 PM
