Sharp LC-C5262U failed, what is this code?
  • tomtom19
    • Aug 2022
    • 6
    I have a Sharp LC-C5262U that just quit on me after many years. The display and sound went out while watching a program. The power light stays on but the TV is unresponsive.
    About 2 minutes after plugging it in, I get what I presume is an error code but I have yet to find out what this means. The Power and OPC LEDs blink together once, then the Power LED blinks twice more.
    https://photos.app.goo.gl/9p7pdfep4BjbekqE8
    I found another post somewhere that referred to this as a "3-1" code, but it was for a different model TV and the symptoms seemed different.
    I'm hoping someone here can point me in the right direction to try to diagnose what component is bad.
    Thanks,
    Tom
    • 12088
    • U.S.
    Re: Sharp LC-C5262U failed, what is this code?
    Try unplugging and then hold down vol- and channel+ while plugging back in and see what happens.
    • tomtom19
      • Aug 2022
      • 6
      Thanks.
      I don't notice any difference if I do that. How long should the vol- and ch+ buttons be held after plugging in?
      I've got the back panel off and I can see a red LED on the mainboard. When I plug the TV in, there is a click and then that LED blinks once a second for 30 seconds, then another click and another 30 blinks, and two more cycles of this before the mainboard LED goes out and the front panel LEDs blink as I previously reported.
        • 12088
        • U.S.
        should come on pretty quick if its going to, maybe 15 seconds but it wont hurt to hold it longer, so the quick fix reset didn't work, will have to dig deeper, try unhook one ribbon cable at a time then power up, the cables go from tcon to panel, always do connecting and dis-connecting with power cord unplugged, to try to avoid any errant surges or such. can you post some good clear straight on pictures of each board and one of the whole back as to see how everything is connected.
        • lotas
          • Jan 2016
          • 4524
          • Russia
          Try doing this:
          Hard Reset
          Step 1: Unplug the television.
          Step 2: Press and hold the "Channel Down" and "Input" buttons on the panel.
          Step 3: Plug the television back in while holding down these buttons. You may need the assistance of another person to accomplish this step.
          Step 4: Keep holding the buttons until the television powers back on. If it doesn't work, unplug the television and try again--sometimes this process doesn't work on the first try.
          Use the remote to navigate the "Service Mode" menu and select "Factory Reset" from the menu. Click "Enter" and the television will begin initializing and shut down. It will then power back on, set to factory defaults.
            • 12088
            • U.S.
            yep, channel down and input. And volume down and channel plus, one of those should work if it just needs a simple reset.
              • 12088
              • U.S.
              this seems to be an older ccfl tv, those panels go short a lot less than the led backlit tvs do.
                • 12088
                • U.S.
                • tomtom19
                  • Aug 2022
                  • 6
                  Here you go.
                    • 12088
                    • U.S.
                      • 12088
                      • U.S.
                      do you see a legend/map of expected voltages? might be by a connector or elsewhere on the powerboard.
                      • tomtom19
                        • Aug 2022
                        • 6
                        No, I don't have any type of schematic or diagnostic guide yet. Hoping I can find one. I'm not getting any backlight, so perhaps the problem is related to the power supply board and its CCFL outputs.
                        • R_J
                          • 9535
                          I suspect your problem is on either one of the inverter boards or it could be a bad ccfl.
                          This tv is based on the LC-46D62U so download it's service manual
                            • 12088
                            • U.S.
                            could be, guess the next easiest test is pull the covers off the inverter boards and test the fuses, they may have capacitors too, if so check them for leaking or bulging tops.
                            • tomtom19
                              • Aug 2022
                              • 6
                              Thanks R_J for the link. That service manual covers model LC-52D62U and mine is LC-C5262U. Very similar but I wonder what the difference is.
                              If I'm reading the tables (bottom of page 6-17) as intended, they describe my error as this:
                              "Initial communication from the main CPU is not received. (After cancelling the reset, request for the monitor model No. is not received.) Communication line failure or main CPU start-up failure."
                              • R_J
                                • 9535
                                Here is the manual for that model, see the outline on page 1
                                  LCD LED TV Service Menu Codes
                                  ALL LCD LED TV SERVICE MENU CODES
                                  Service Menu Code with Board Name
                                  China Universal Board / Jumper Board Service Menu Code
                                  Changhong Ruba Service Menu Code
                                  Ecostar LED TV Service Menu Code
                                  Orient LED TV Service Menu Code
                                  Haier LED TV Service Menu Code
                                  TCL LED TV Service Menu Code
                                  Samsung LED TV Service Menu Code
                                  LG LED TV Service Menu Code
                                  Videocon LED TV Service Menu Code
                                  Supra LED TV Service Menu Code
                                  Toshiba LED TV Service Menu Code
                                  Symphony LED TV Service Menu Code
                                  Veste/ LED TV Service Menu Code...
                                  10-31-2024, 03:58 AM
                                • MarkC1970
                                  Sharp LC-40FG2241KF failed LED boost converter
                                  by MarkC1970
                                  My Sharp LC-40FG2241KF with a TP.MS6486.PB711 mainboard has a failed LED boost converter. The FET (AOD458) was s/c and the rectifier/blocking diode (SR320) was also s/c. Both were changed as well as the input and output caps.
                                  On powering the TV we get 55v on the LED rail. Immediately we take the TV out of standby the controller (OB3350CP) starts to trigger the Gate of the FET and it dies again (with smoke no less). The inductor is incredibly low resistance at 0.09 Ohms and I suspect it is short and so the FET is directly grounding the 55v supply, but I may be mistaken. Scoping the...
                                  02-15-2022, 06:47 PM
                                • Sorrow1
                                  Intergraph TDZ 2000 mainboard post code 2F/2E
                                  by Sorrow1
                                  I try to repair an old Intergraph TDZ 2000 from 1998. It is a dual Pentum II machine based on Intel 440LX chipset. There is a non-removable bios chip named PhoenixBios B1787840. I cannot see any physical damage to the board. All caps look OK.
                                  It shows no picture and POST stops with code 2F/2E regardless whether or not any graphic card is plugged in. If memory is removed, it stops on previous code 28/17 and stars beeping. I tested both CPUs in another machine and I also use RAM from another machine.
                                  When I recorded video of POST card and played it in slow...
                                  01-03-2024, 04:13 AM
                                • SdlewisSr
                                  Sharp LC-80LE632U 2-5 blink code
                                  by SdlewisSr
                                  I have a Sharp LC-80LE632U with a 2-5 blink code. I have narrowed it down to the T-Con/Panel. I get the error if both or either ribbon cable is connected between the T-Con and the Panel. If I disconnect both ribbon cables, I get no error and the TV powers up just fine.
                                  Does anyone know if this is a definite bad Panel or is there a chance that the T-Con could still be at fault?
                                  07-11-2021, 07:36 PM
                                • DynaxSC
                                  MSI PRO Z690-A DDR4 (MS-7D25) - stuck during boot every second time - debug code 16 & A1
                                  by DynaxSC
                                  Hi Folks
                                  I have an MSI PRO Z690-A DDR4 (MS-7525) which underwent LGA1700 replacement and had a missing resistor in the VRM section. The missing resistor RV170 (49,9Ω) has been resoldered, and I have also replaced a demaged LGA1700 socket.
                                  Generally the board does boot to Windows, but not always in the first attempt, but after the second attemp to boot the board with Power Button. Also restarting the board from Windows ends up with stuck boot process, but restarting the board again (long push Power Button or switching off and on PSU). Under Windows etherything works
                                  09-29-2024, 04:27 PM
