SLED5517 bad TCON or main?
  • sammonselectronics
    • Sep 2021
    • 5
    I was watching the Sansui 55 when the right-hand side went a little dark and then color smeared some next the screen looked washed out.I restarted and now the set has no picture or OSD. Has Good sound and backlights are bright. I am thinking TCON be they usually have pixelating or lines or stripes. as they go out
    Sansui does not offer parts for this unit so anything I try will be used parts.
    Should junk this crapola or try a TCON?
    Y'all be safe
    David
  • nomoresonys
    • 12206
    • U.S.
    Re: SLED5517 bad TCON or main?
    I would try a tcon they usually don't cost a lot.
    • tech9pc
      • Sep 2021
      • 49
      I have an RCA RTU5540-D doing the same thing. I am pretty sure it is t-con. Only problem is finding one lol
      • advant
        by advant
        02-03-2020, 12:25 AM
      • x_orange90_x
        TCL 50S535 bad tcon or panel issue?
        by x_orange90_x
        Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
        03-29-2025, 11:02 PM
      • cheeky2
        by cheeky2
        05-25-2024, 03:27 AM
      • Dani_2024
        by Dani_2024
        10-28-2024, 05:06 PM
      • maxim2511
        LG 55EC930V OLED - swich on swich of no screen
        by maxim2511
        My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
        Then I get an idea to take it apart and clean boards from dust.
        In side of Tv was not so bad, I take compressed air in can, and gently blow up.
        Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
        05-14-2021, 02:21 AM
