55' Mitsubishi RPT
  • mpobanion
    • 23
    55' Mitsubishi RPT
    mpobanion again,
    Checking to find out about any problems that a rear projection TV 55' Mitsubishi 2001 which has vertical bow top & bottom of screen, does anyone know what might be causing this issue. Any suggestions where to start troubleshooting, circuit or a weak component?
    Thanks,
    Mike
  • mpobanion
    • 23
    Re: 55' Mitsubishi Rear PTV
    It is a 2001 rear PTV, correction to RPT in title it was a mistake.
    Wizard would you possibly have some insight? I know this is older technology and you probably work on the new stuff.
    Thanks, Mike
    • Wizard
      • Mar 2008
      • 2296
      Re: 55' Mitsubishi RPT
      One of color? Or all?
      Bowed vertical? That's top and bottom. Horizontal bow is side to side.
      Cheers, Wizard
      • mpobanion
        • 23
        Thanks, for reply Wizard
        All of the colors have a Horizontal bow side to side.
        Mike
        • mpobanion
          • 23
          Hi, Wizard
          It is Veritcal and all the colors, smiley at top and frown on bottom.
          Mike
          • Idzfix
            [WTB] Avita Liber 14" NS14A2MY036P – Casing / Housing (Top/Bottom)
            by Idzfix
            I'm looking to buy a replacement **casing / housing** (either top cover, bottom base, or full chassis) for my laptop:
            šŸ“Œ Model: Avita Liber 14"
            šŸ”¢ Model Number: NS14A2MY036P
            My original casing is cracked and I’m hoping to replace it. I’m open to:
            - New or used parts
            - Full chassis or just top/bottom shell
            - Compatible parts from other Avita V14 / NS14A2 / NS14A8 models
            If anyone has a non-working unit with intact body parts or knows where to get one, please let me know....
            08-05-2025, 09:48 AM
            Light that has a bug zapper in bottom section of light fixture the LED light module took a crap but the zapper still works
            So I got the bright idea to remove the LED light module from the fixture and put it on top of another enclosure and keep using the zapper
            The removal of light module was a successful and now I just have to cut a hole in the enclosure and put a power cord that has an on and off switch on it
            You are lucky to get about two years of service out of one before the LED module starts flicking and just stops working because it is mounted on an aluminum plate and these are hard to solder on it and it is not worth messing around with them and especially this one because it has line...
            09-07-2024, 07:26 PM
          • fredyjbi
            please help friends thinkpad T470 error post "bottom cover tamper detection error"
            by fredyjbi
            please help friends thinkpad T470 board CT470 series NM-A931 error post "bottom cover tamper detection error"
            I've already
            flashed the bios clean me and updated from the Lenovo site, then removed the switch and immediately jumped the S3 from pins 1 to 4, 2 to 3 but the problem remained the same, thank you
            06-15-2024, 09:56 AM
          • kdaniel
            Hitachi 58HK6100U - Horizontal Lines (Bottom third of the screen)
            by kdaniel
            As stated by the person I collected the TV from, it just stopped working overnight. However, I still gave it a go to try and repair it.
            There is a thread on the same TV but with slightly different issues where they had to tape connection points on the ribbon cable, so I want to see if this is repairable by any chance.
            After bringing it home and plugging it in, the TV turned on with its backlight working but had no picture. After removing the back cover, the first thing I tried is to unplug one of the ribbon cables and the situation is as follows.
            Left...
            11-16-2022, 09:23 AM
          • hugocarmo
            Mitsubishi HS-E82 VCR Bad Picture
            by hugocarmo
            Good morning everyone.
            This time I have a Mitsubishi HS-E82.
            It was a bargain that I found with original remote included.
            The problem reported by the owner is that it was working but no output video.
            I took it appart and immediately saw that three 470uf capacitors were leaking on the signal board and one in the Hi-Fi board the same value too. I have located them in the pictures in red marker.
            I replaced them, cleaned all the liquid remains and the video output got working again.
            I saw too that were three surface mounted capacitors, two near the 470uf and...
            11-21-2023, 04:11 AM
