esa plasma panel gassy
  • Tvbob
    tvbob
    • 204
    Hello fellas, I acquired a ESA (LG) dpd4294lv1 plasma tv mfd 2005
    It came with an extra (Z) sustain board. Both boards load down PSU.
    the (Z) sustain supplies half of the "potential" to the panel,What are the signs of air in the panel. The vacuum nipple is in tack. Should i try a 3rd (Z) sustain board . thanks
  • PlainBill
    • Feb 2009
    • 7034
    Re: esa plasma panel gassy
    If I recall correctly, the troubleshooting directions for the panel suggest troubleshooting power supply problems by disconnecting the power cables to the X, Y, and Z modules in turn. If the power supply recovers when power is disconnected from a particular module, the next step is to replace the module.
    In this situation, my approach would depend on the severity the board presents to the PSU. If the power supply fails to come up at all (massive overload), I would check the semiconductors in the Z-sus. If I found any shorted I would either replace the semiconductors or the Z-sus as appropriate.
    If, on the other hand, only one of the power supply outputs would not reach full voltage, I would check the power supply itself first.
    PlainBill
    • Tvbob
      tvbob
      • 204
      Thanks plainBill I bought this tv at an auction,i don't know any history of it (being banged around etc) With Vcc to the (z) sustain unplugged, Power supply fires up with sound, Have led's lit on the formatter board. Both (z) sustain modules load down the power supply and its cycles 2 times and shuts down. The (z) sustain board drives half the plasma panel... Can i disconnect the panel from the (z) sustain module and run it? What is the the output voltage ? Can it be ran into a dummy load ? Back in my day (crt days) when you had air in the tube. There was arcing in the neck from the focus and G1 grids Thanks again.
      • PlainBill
        • Feb 2009
        • 7034
        Actually, the Z-sustain board drives the entire plasma display. As do the Y-Sustain and the X-drivers. They just provide the drive to different elements of the display.
        I don't have enough experience to know if a broken plasma would load down the Z-Sustain board. I DO have a few suggestions, however.
        Wizard has extensive experience with plasma TVs. He may have explained the symptoms of a cracked panel.
        Since the set was made by LG, go to scribd.com and search for LG plasma training manual. The translation is horrible, but you can learn a little about how they work. And what parts not to touch.
        Search for the part number of the Z-sus. If it is one of those with a hybrid, they are notorious for shorting.
        PlainBill
        • Tvbob
          tvbob
          • 204
          Thanks again plainbill, What I meant to say is The (z) sustain supplies half the potential to the plasma panel. I bought a pdf manual on ebay Very bad Chinese translation. Shows schematic of main PSU. Nothing nothing on the sustain boards, Says there is an (IPM) ic intelligent power module on the (z) sustain but no schematic or voltages. Thinking about about connecting the output of the (z) sustain to a neon tube back to cold ground . IF the set stays on I must have an gassy panel.I am kinda curious if I will get any glow out of the neon, It takes about 3-5 kv to lite neon.
            by sam_sam_sam
            03-31-2024, 02:12 PM
          • alltvrepairs
            Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
            by alltvrepairs
            I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
            I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
            Any one met this problem in the past?...
            10-08-2025, 07:34 AM
          • lp20th
            Samsung Plasma TV Power Supply Issue
            by lp20th
            I have a vintage 2008 Samsung 50” Plasma TV, Model code PN50A550S1FXZA with a power supply part number BN44-00222A. I repaired the power supply board several years ago finding a couple of cold solder joints on the back side of the board and it's worked great up until now. Recently a fried sound occurred with the smell of burnt electronics and the TV shut down. Trying to turn it back on yielded the typical relay clicking with no TV boot up. Upon investigation, removing feeds to the other boards within the TV it was found that disconnecting the logic board from the power supply allowed the...
            11-28-2023, 10:28 AM
            by sam_sam_sam
            07-01-2024, 06:34 AM
