Samsung PN51E550D1FXZA plasma no power up 2 blinks
  • M80
    • Aug 2022
    Samsung model # PN51E550D1FXZA plasma TV after a lightning hit (LAN cable was connected to TV). Standby LED on ok, but when pressing the power button, getting 2 blinks on the red LED, the screen flashes white for a second, and then cycles through this loop routine.
    ALL voltages Vs, Ve, Vsc, Va check ok at SMPS output pins and at Main Board connector and X/Y drive board test points.
    Noticed the Logic Board LED lights up green for a couple of seconds, hums lightly, then goes off during this cycling.
    I've reseated ALL connectors and none of the boards have any burned traces or parts, and no caps are swelled.
    When disconnecting the Main Board connector from SMPS, nothing happens, and no Standby light. When disconnecting X/Y board from SMPS, the panel does not light up.
    Ran test with main board disconnected, SMPS Ps_ON jumpered to ground with Logic Board pins 3 & 4 jumpered. TV powered on showing good test patterns. Logic Board seemed to now flash in a normal cadence.
    What should be replaced?
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Samsung PN51E550D1FXZA plasma no power up 2 blinks
    The mainboard.
    • M80
      • Aug 2022
      Thanks. Any good recommended parts sources? I've had mixed results with ebay used boards.
      • diif
        • Feb 2014
        • 6978
        • England
        Check it over for dry joints, you might not need to replace it.
        • M80
          • Aug 2022
          Replaced the Main Board and all working now, thanks! Lots of microchips on the board...I saw someone had replaced a voltage regulator IC and got it working.
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • ohren
            Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
            by ohren
            I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
            I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
            The models launched in 2018 and 2019 respectively....
            09-08-2023, 05:24 PM
          • C152Heavy
            Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
            by C152Heavy
            Summary for TL-DR readers:
            • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
            • Have obtained Samsung schematic & service documents - Can upload if helpful.
            • Have read ALL applicable threads
            • C1818 and CP820 replaced as low hanging fruit
            • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
            • VCC pin (18) of PFC...
            01-11-2023, 02:53 PM
            09-07-2024, 05:50 AM
